36hp Mods
<< < (3/13) > >>
RichardinNZ:
Made some decisions; 2mm flycut and 33mm (Okrasa 36hp size) intakes.  I can get HD springs but will I need them? Not getting into the bottom end (which seems sound) so stock cam and can't locate anything more than stock retainers and keepers.   Will my new setup rev much higher so meaning I need the springs or will I increase wear with no gain?
Richard
RichardinNZ:
Anyone have any thoughts on this...looking to order as our show season is coming!
Richard
RichardinNZ:
Got my heads back...mild mods for most of you on here but moving towards what I want for the '58...as planned, 2mm flycut (will give 7.5:1 CR up from stock 6.6:1), 33mm intakes, mild porting and HD valve springs.  Now time to get the engine back together, get the linkage sorted for the dual 28PCI carbs and off to our Spring Jamboree (18th November).
Doktor:
Manifold for 28pci carb is your hand-made work ?  :D
They look great !
RichardinNZ:
Manifolds appear to be Autotechnik Express modified by a previous owner with new balance tubes and the old balance tube threads used to mount the linkage....they will be good but I just need to get the linkage sorted.  I'll post some more pictures when things progress.
Richard
Navigation
[0] Message Index
[#] Next page
[*] Previous page
