Lifter bores
Paul Bahnstormerz:
Heads done 😊
nicolas:
Quote from: max Der Bahnstormerz on May 03, 2016, 08:30:30 am
Just an adjustable hand reamer, a hand drill and a tool bought from Berg's 25 years ago to face the lifter bores.
Then finished off the bores with 120 grit loosely wrapped around a rod in a drill to hone the bores.
Nothing fancy, just lots of care taken not to remove too much material.
cool, but i assumed you fitted the bushes yourself as well. it looks really good.
max Der Bahnstormerz:
Clearance checks all done, should be able to button up the bottom end tomorrow ;D
Jesse/DVK:
Nice to see that you used the split bearing nr3
Paul Bahnstormerz:
That doesn't look like the cam we were looking at over the weekend!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
