one piece window seals
<< < (3/4) > >>
Tourist:
Quote from: RobtheManx on July 23, 2018, 20:42:39 pm
https://www.woolies-trim.co.uk/product/1259/window-weatherstrip
https://www.woolies-trim.co.uk/product/1734/window-weatherstrip
Thats what I used . I used the larger one on the inside , smaller one bonded to black painted stock aluminium trim on the outside . I had to pie cut the ends to make them curl up , and trim the top part so it tapered out , but worked really well . They're made of plastic and rubber , so fore flexible than steel lined ones , and won't rust . I bonded them to the door with tiger seal , just scratched up the smooth plastic surface first .
Good smooth felt on the inside helps the glass rum smooth .
Also , their window channel is a million times better than the crap you used to get with one piece window kits .
I'll try post some pics of my results .
Rob
Good evening Rob,
I hope that you do not mind me asking (I know this probably quite an old topic now), but which of the Woolies window channels did you use?
There are few ones listed and am not sure which to go for.... :-[
Any help/further information greatly appreciated  8)
Thank you in advance,
Martin :)
RobtheManx:
Hi Martin , I used this one . great quality .
https://www.woolies-trim.co.uk/product/1023/flexible-window-channel
cheers , Rob
RobtheManx:
Quote from: Martin S. on September 18, 2018, 20:19:54 pm
Quote from: RobtheManx on August 02, 2018, 21:20:48 pm
It was a pain in the arse job , but the seals hold the glass really tight , so way less rattle , and they roll up and down as smooth as a stock window .
Also from woolies , I got a pair of leather vintage car check straps . much better than those awful cable things .
Cheers , rob
Can I see a pic of the check straps please?
OK i'll get a pic this weekend
Tourist:
Quote from: RobtheManx on October 18, 2019, 22:35:47 pm
cheers , Rob
Good afternoon Rob  :)
Thank you  ;D
All the best,
Martin  8)
VWGlassee:
I also used the woolies window seals. Grear great quality!
I used the large ones on the inside and outside  ;)
Yannick
Navigation
[0] Message Index
[#] Next page
[*] Previous page
