4.57 vs 4.13 ring and pinion
<< < (2/2)
mikko k:
Quote from: Bad bug on January 21, 2020, 23:17:59 pm
Quote from: mikko k on January 20, 2020, 00:10:54 am
4.13? Do you mean 4.125 beetle gearbox ratio? It does not fit to bus box.
4,571 is the strongest ratio available to bus box.
3,875 is the strongest ratio available to beetle box.
They now have a 4.13 ring and pinion for the 091 bus box. I can't see why people would want to remove the 091 ring and pinion and replace it with this unit.
People have different needs and I dont know why other people need to understand. Some wants 1835cc engine, other 2L and next one 3,4L Pauter turbo engine...
You need ring and pinion. You need to know why and which one... Good luck!
Udo:
Quote from: mikko k on January 26, 2020, 22:41:24 pm
You need it to get a bus gearbox longer in ratio. Good for a bus on German streets
Navigation
[0] Message Index
[*] Previous page
