ARP flywheel bolts for Oxyboxer.
PPRMicke:
Quote from: Bad bug on August 07, 2022, 21:58:39 pm
@Eddie DVK
Do these torque to 120ft/lbs i see where you have to machine the flywheel.
@PPRMicke
APR website says 105 ft/lbs for these bolts.
3 starters with 2 discs and slick (300+ Hk Then they were screwed off with a damaged crank and flywheel
Then it was just a matter of redoing, doing the right thing, putting the ARP there 5 years later, the same screws are there
It's not how hard you tighten a screw that decides. It's the strength that the screw can handle
It is the only make (Arp) that I dare to use today for the flywheel
But I'm talking about much higher Hp
/// M
Bad bug:
Thanks for the help. I am assuming these were a straight bolt in.
Navigation
[0] Message Index
[*] Previous page
