'75 Original Hot VW Cover
<< < (11/40) > >>
JS:
Whatīs the story about the different dash plates? The Dashes in post #34 and #42 are clearly not the same. The latter has only two small gauges while the other one has three.
The one in #42 looks cracked just above the "map" light. Was that why it was replaced? Jim?
EDIT:On closer inspection it seems like on the "first" version the plexiglass is riveted to the dash itself, perhaps explaining the stress causing the crack while the other one MAY be using regular philips screws?
Frank LUX:
Quote from: JS on January 19, 2008, 00:15:09 am
The one in #42 looks cracked just above the "map" light. Was that why is was replaced. Jim?
WOW....
That's an interessting Question.... ;)
Indiana "JS" Jones vs Jim Holmes!!!
Frank
deano:
I do believe Jake replaced the dash panel since it was cracked around some of the rivets. Possibly post crash dash? Good eye. Does the driver's seat upholstery look different as well?
JS:
You are correct deano, itīs not even the same seat IMO. Did this car have a back seat? Was that too retrimmed in the fat bisquit pattern?
Where there two of those too since thereīs been two different style front seats?
empicolector:
yes please post more picture jim
Navigation
[0] Message Index
[#] Next page
[*] Previous page
