Deck lid stand offs
<< < (3/5) > >>
H67bug:
Quote from: Roman on October 08, 2006, 18:15:29 pm
I have Berg 52:s on tall manifolds and it is impossible to close it. I don't hink I can close the lid if I remove the stacks completely either.
To prop it up in the bottom is not an option either, when it cleared the stacks it was a two feet gap.
2 feet gap! ;D... now that would of been amusing to see. I only have 48s so the issue is not quite as bad.  ;)
alfie the monster:
Prop it at the bottom then H  ;)
If Seedo's around, it may end up that way anyway  ;D
Sarge:
If your going to prop your lid a bit, best to do it at the bottom.  This will circulate air over the rear engine tin that seperates the hot exhaust from the engine compartment and help cool things down as well as give you a little more clearance.  Like you say, best to perservere!
El Diablo Gris:
It's all about " D-cups" and playing with the bottom a little !  ;D ;D ;D
El Diablo Gris:
One more .............
Navigation
[0] Message Index
[#] Next page
[*] Previous page
