May 24, 2024, 07:37:03 am
63calLQQK
The weight saving thread
33
34
Topic: The weight saving thread (Read 533732 times)
Re: The weight saving thread
Reply #990 on:
July 16, 2023, 07:41:50 am »
yes that is a carbon shifter handle[about half the weight] and alternator pulley [1/3rd the weight]
Reply #991 on:
July 23, 2023, 12:17:41 pm »
Doors fitted to car with new hinges and handles, all works good
Reply #992 on:
July 29, 2023, 17:33:52 pm »
More stupidity
Fuel tank clamps in carbon, steel 24g, carbon just over 7g each, 4 is 29g!!!
ibg
Reply #993 on:
July 30, 2023, 03:48:38 am »
you just need to sell them with titanium or aluminium bolts, though aluminium might be a bit weak in a crash situation
Reply #994 on:
July 30, 2023, 17:06:43 pm »
Quote from: ibg on July 30, 2023, 03:48:38 am
I will try not to crash then
Did fit a pulley today to one of my cars and seems to work ok, will give it some milage and high rpm tests now and see if it falls apart
https://www.youtube.com/watch?v=MxwOAIo1W0w
Last Edit: July 30, 2023, 18:42:51 pm by richie
Reply #995 on:
December 25, 2023, 11:17:44 am »
Reply #996 on:
March 23, 2024, 01:10:12 am »
Still the best thread on the entire internet
BFB
Reply #997 on:
March 24, 2024, 15:41:14 pm »
Those valve covers are definitely cool, id bet you could sell those especially if you made a set thatd clear ratio / high lift rockers.
Only argument i might see against them would be heat transfer. How much heat is normally dissipated thought an aluminum cover though?
Reply #998 on:
March 26, 2024, 09:03:56 am »
Quote from: BFB on March 24, 2024, 15:41:14 pm
How much lift clearance do you need? these clear 650thou lift already, probably more but not built anything for a while with vw style covers that lifts more than that
and I don't run aluminium covers anyway
PPRMicke
Reply #999 on:
March 26, 2024, 09:35:52 am »
Can't figure out how to lighten a Vw front
You can put lead in the front if you have to drive fast
Because having the front wheels 1m up in the air does not give good times
/// M
Reply #1000 on:
March 26, 2024, 19:48:16 pm »
Quote from: PPRMicke on March 26, 2024, 09:35:52 am
/// M
While i mostly agree, if we do more work on the front end aero to try create more downforce then we can safely run a lighter car
mymedusa
Reply #1001 on:
April 02, 2024, 10:13:24 am »
Bugwelder in Germany has 2 new Alternativ(Drehstrom!), old Style 90mm and 105mm
45Ah 12v
90mm = 2,5kg
105mm = 3,1kg
Catbox
Slave to internal combustion.
Reply #1002 on:
April 23, 2024, 21:23:48 pm »
This thread has always been fun to read to see the innovations that come out.
Those carbon parts are awesome Richie.
33
34
