September 22, 2026, 22:18:09 pm
| | |-+  what flywheel do i need to prevent grinding my bellhousing?
Author Topic: what flywheel do i need to prevent grinding my bellhousing?  (Read 5098 times)
beetletom
« on: September 13, 2009, 15:03:03 pm »
need a large dowel flywheel, but smaller size?
and i belive a 1 year only wheel? or from a 1500 singleport??  Huh
« Reply #1 on: September 13, 2009, 15:21:40 pm »
why buy a new part to fix a very easy problem - Just grind the bellhousing  Smiley
beetletom
« Reply #2 on: September 13, 2009, 15:30:06 pm »
i'm scared of it going up in flames!!
would it be easy enough to take out the studs??
« Reply #3 on: September 13, 2009, 15:37:08 pm »
What do you mean by a large dowel flywheel?
As Lee says, just grind it. It won't go up in flames! Just make sure you brush the dust away as you grind, and wear a mask... It'll take you no time at all and will save you money and hassle swapping flywheels.
Quit whingeing and get on with it. Grin
« Reply #4 on: September 13, 2009, 15:43:58 pm »
Thankyou for the back up  Wink
JUST DO IT!!!!!!!!!!!!!!!!
beetletom
« Reply #5 on: September 13, 2009, 17:09:07 pm »
ok i'll give it a go!  Cheesy
