July 02, 2026, 09:03:46 am
352213 Posts in 28925 Topics by 6921 Members
Latest Member: bigsiembowski
| | |-+  Race clutch advice
Author Topic: Race clutch advice  (Read 3811 times)
Fastorq
« on: September 13, 2009, 20:10:30 pm »
My 1425lb buggy has a Kennedy StI with a CB 4 puck plate.
After 14 passes the 4 puck has glazed and the clutch started to slip around the 10th or 11th pass.
What should I do ... I'm told a Black diamond plate with the StI would be good but fiercer and will hit harder maybe cause gearbox breakage.
Stay with the 4 puck - have it bead blasted and move up to a StII Kennedy.
The glazing on the 4 puck showed full contact on the pressure plate side but only half contact on the flywheel side so is this an indication of not enough pressure plate pressure.
I really dont want to have to pull the engine and replace pressure plate and friction plate every 10 passes but equally want to keep the box in one piece.
Regds
DavidR
Buggy is a 2165cc draw thru 260hp turbo running consistant low 11s and once a 10.8 - only ever done 14 passes.
« Last Edit: September 13, 2009, 20:21:05 pm by Fastorq » Logged
10.89 @ 125mph
Damp Klimate Panzer
dangerous
« Reply #1 on: September 13, 2009, 21:18:14 pm »
There are may upgrades you can do,
but I would guess that your Stage one needs to be set up with the depth of the flywheel correct.
First put a straight edge accross the face and note the conical distortion.
Once you machine it flat and the flywheel too,
you may still need to shim out the pressure plate from the flywheel,
so that the diafragm does not go over centre.
I have to do that on every one I do,
even though the FW is within VW specified depth.
Jesse Wens
« Reply #2 on: September 16, 2009, 11:53:09 am »
so there isn't an ideal dept for the flywheel? It has to be checked with the flywheel and pressure plate to b used?
