August 12, 2026, 10:28:08 am
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  sand seal alu pulley
Author Topic: sand seal alu pulley  (Read 4464 times)
« on: September 24, 2009, 11:20:00 am »
Hey guys,
because my engine is leaking a lot of oil from the pulley, i would like a sandseal...
but.. its an alu pulley... do they live a long life with the seal or is it a matter of months before the seal cuts in the pulley?
Thanks!!
« Reply #1 on: September 24, 2009, 16:05:43 pm »
if you are concerned, go with all steel or steel hub pulley then..
« Reply #2 on: October 03, 2009, 12:39:51 pm »
Hello,
Its not that easy,
the trigger wheel for my ignition is mounted and balanced on the pulley,
and i am running it allready...
maybe if i can find the right size tube i can make a sleeve that goes around the pulley end?
