September 02, 2026, 00:43:17 am
Latest Member: Lotus67
| | |-+  MSD distributor timing help
Author Topic: MSD distributor timing help  (Read 5256 times)
reijo5
« on: September 27, 2009, 18:52:41 pm »
Ok i was gonna set my msd distributor to 30 deg @ 3000 rpm +  like a 009 , but it has the heavy  silver spring s in so full advance is not going to be in till over 5000 rpm also i checked to see which adv stop was in , expecting to see the blue one as
i have a bag with the other springs /stops in and the blue was nt in the bag , but it was not blue just lightly rusted Cheesy ( lovin the uk climate) but it looked only slightly smaller than the black stopand larger than the silver so maybe it used to be blue ? if i remove and measure what size should it be?  so what should it be set at ? its a 2276 130 cam 48 idas timms stage 2 heads  ,
and also are the big silver springs and blue advance stop right for this set up ? this is how i bought it.
Thanks for any help
jamie
bang
« Reply #1 on: September 27, 2009, 19:53:58 pm »
i am running with one light silver spring and a blue spring and then i use the biggest black washer for adwance stop..
reijo5
« Reply #2 on: September 27, 2009, 20:04:54 pm »
Thanks bang , what rpm do you get full advance with that ? does cc make a difference to how you should set up your springs/stop  Huh
Rasser
« Reply #3 on: September 27, 2009, 20:09:52 pm »
You will probably want it to be fully advanced at somewhere between 2600-3000rpm, and the advance should START roughly 50-100rpms ABOVE your idlespeed ( a lot of people have their advance and idle speed mixed together, and this will result in bad idle). A good starting point would be a 20degree total advance (10-30 degrees - or similar). You will have to fine tune it to your engine, but at least this will get you started.
Luckily a spring change is quickly done on a msd distributor, so you should have it set up fairly quick.
Avoid detonation - Good luck  Wink
1955 type1
1966 type2 13w deluxe
bang
« Reply #4 on: September 27, 2009, 20:31:30 pm »
on msd homepage you can see what the springs does and the adwance stop. i set mine up so it starts at 1500 rpm and stops at 2800 rpm.
and it it set on 28 degrees at full adwavce.
my engine is a 2779ccm with 12,6: 1 in compresion.
reijo5
« Reply #5 on: September 27, 2009, 20:42:05 pm »
Thanks rasser & bang you have been a great help guys.
MSD homepage why did nt i think of that  Cheesy Roll Eyes
