October 14, 2026, 17:17:58 pm
| | |-+  Lifter question
Author Topic: Lifter question  (Read 4619 times)
« on: September 28, 2009, 22:51:06 pm »
I just pulled my engine down and noticed a couple of the lifters have started pitting (just started).  The cam looks pretty good to me.  The lobes just seem polished over the nose with no wear lines.  It just looks good.  I promised myself a while back that if I ever split the case again that I would put in a set of Udo's lifters.  Now the question:  Do I need to change the cam or would it be OK because of the lifters I will be using.  My thinking is that I should be OK with just the lifter upgrade, but I would like comments pro and con.  Thanks!
SlingShot
« Reply #1 on: September 29, 2009, 13:26:53 pm »
Apparently that's the beauty of UDO lifters is they last forever, you can change cams, you don't have to keep tract of what lifter goes where, and I think their lighter than other performance lifters?
Will Race For Beer !!!
« Reply #2 on: September 29, 2009, 14:16:21 pm »
Hey Don,
New cams are less than $100 and you can find Engles for around $60-$70. Its cheap insurance to not have to worry about reusing a used cam.
« Reply #3 on: September 29, 2009, 14:40:11 pm »
I understand, but the cam looks great.  I have had three cams go flat and this one doesn't look like any of them.  I will not reuse the lifters, but I was thinking I could reuse the cam.  Just wondering how many people on here have run used cams...
SlingShot
« Reply #4 on: September 29, 2009, 21:00:16 pm »
I run a used cam. I would almost perfer to run a used one, then you don't have to worry about it going flat.
« Reply #5 on: September 29, 2009, 21:21:52 pm »
hi
You can use the old cam , no problem . Better you messure the lift on each lobe to be shure the cam is ok
« Last Edit: September 29, 2009, 22:05:37 pm by Udo » Logged
« Reply #6 on: September 29, 2009, 23:05:26 pm »
Thanks Udo, I was hoping you would chime in!  I will definitely measure the lift.
