October 14, 2026, 14:31:40 pm
| | |-+  air relief in filter
Author Topic: air relief in filter  (Read 4689 times)
CHR!S/DVK
« on: September 29, 2009, 21:45:08 pm »
i recently got myself a set of original kadron air filters and noticed that one of the bottom parts of the housing has an air relief tube(see picture).
as this bottom is a selfmade part i would like to replace it by an original one.
the replacement part i found doesn't have this air relief tube.
my question is, what i the use of this air release? is it meant to be connected to a breather box?
i have seen other air filter which had it.
is it essential, so that i cannot replace it by a disclosed original one?
« Last Edit: September 29, 2009, 21:58:16 pm by CHR!S » Logged
Member of DVK - Der Vollgas Kreuzers
« Reply #1 on: September 30, 2009, 01:51:41 am »
That tube is meant to connect to the stock vent at the oil filler.  If you have that vent connected to your breather box, connect it to your air cleaner.
CHR!S/DVK
« Reply #2 on: September 30, 2009, 09:19:01 am »
thanks for you reply bruce, the air cleaner on my stock carb is also connected to the vent of the oil filler, but is this connection essential?
« Reply #3 on: October 01, 2009, 10:18:32 am »
this fitting is often seen on IDFs and DRLA carb that run air filters.
and doesn't your breather box have 4 fittings?
i'd say left rocker cover, oil filler, right rocker cover, right side air filter, bro. it would allow you to hook things up nicely tucked away, too! Smiley
« Reply #4 on: October 01, 2009, 16:58:58 pm »
You don't "need" it, but it may help prevent oil from exiting the crankcase at the pulley.
