November 02, 2026, 10:29:17 am
Latest Member: thunder_bac
| | |-+  Cam/rocker questions - help please!
Author Topic: Cam/rocker questions - help please!  (Read 14331 times)
« on: September 30, 2009, 11:47:06 am »
Hey guys I have a quick question about cam/rockers - The guy I am building the 68 for has just aked me to fit a set of Scat 1.25:1 rockers to his 1915cc type1 motor Undecided
Now this Motor already puts out 124bhp at the wheels - pretty good I think,
Now the main question is - It runs an Engle120 BUT he doesn't know what the rockers are (he thinks they are 1.1:1)
So what SHOULD a engle120 cam run with and if its NOT with 1.25 rockers then How do you think this will "Effect" the motor Huh
Let me know what you think guys  Smiley
« Reply #1 on: September 30, 2009, 17:56:15 pm »
Anyone  Undecided
John Maher
« Reply #2 on: September 30, 2009, 19:54:37 pm »
Engle 120 will work with 1.1 or 1.25 rockers.
Only way you can be sure what you have right now is to measure lift at the valve - but it goes without saying you were going to do that anyway, weren't you?  Wink
Some Scat '1.25' rockers actually measure out closer to 1.4:1  Shocked
Don't trust the label on the packet or the catalogue description.
Once you've set geoemetry/shimmed the rockers/got pushrod length right, measure ACTUAL lift at the valve.
it's not recommended you run 1.4s on E120 - you could get yourself into big trouble very quickly.
E120 w/1.25 rockers (true 1.25) works nice with the right head and carb combination.
John Maher
« Reply #3 on: September 30, 2009, 20:35:53 pm »
Thankyou very much John - Perfect info as always   Smiley here's the project: http://cal-look.no/lounge/index.php/topic,7573.0.html
I did not build the motor (the owner did with some help Undecided) and up until now we were just gonna keep "as-is" but now it looks like I'll be making a few changes,
I am kinda happy I am now looking into the motor a little more as there are a few "issues" I have never been happy with but I will go into them later, Today I stripped the heads and here's what I found:
1 - it has 280mm 3/8 ALUMINUIM pushrods
2 - it has DUAL Valve springs
3 - it has what looks like ALUMINUIM retainers Undecided (anodized blue)
4 - 5.5mm of spacers/shims under the Rocker sharfts  Shocked (my guess is they did this so they didn't have to shorten the pushrods Undecided)
Any more thoughts  Huh Smiley
« Reply #4 on: September 30, 2009, 21:03:55 pm »
I would use the 1,25 rockers that fit on the  original shafts (hope they are hd with screws at the end) and chrome molly pushrods .
Rasser
« Reply #5 on: September 30, 2009, 21:54:15 pm »
last set 1.25 rockers i used, measured out at 1.34:1  Undecided
I would use 1.1:1 rockers, they will let the valvetrain/springs live much longer.
1955 type1
1966 type2 13w deluxe
« Reply #6 on: September 30, 2009, 22:18:25 pm »
Ok guys here's a few more spec's:
- 69x94 (1915cc)
- counterweighted crank
- unknown rods
- CR = 9.2:1 (unknown deckheight/chamber cc)
- Engle 120 Cam
- Normal cam gears
- 40x35.5 valve heads (vw/gex/mexico Undecided) whith HEAVY port/polish,
- Stainless Valve,
- 3 angle valve job
- Suspected Aliuminuim retainers Undecided
- Dual Valve springs (Waterboxer Inner & Remell Outer - unknown spring rates)
- "Bolt up" rocker sharfts (with 5.5mm of shims under them!)
- 280mm 3/8th ALUMINUIM pushrods
- 1.1:1 Rockers
- Swivel feet adjusters
- And all this runs on a pair of 44idf's (32 vents, unknown jets) and a 1 3/" stainless header system
Any further thoughts guys  Smiley
« Reply #7 on: September 30, 2009, 23:28:15 pm »
Give it 36 vents, should run like a champ Wink
« Reply #8 on: September 30, 2009, 23:58:47 pm »
I was thinkin it could use a little more Airflow  Wink I have always felt the engine was "soft" even with 124bhp AT THE WHEELS, The 1 3/4" header is VERY long with 2 (two) very large mufflers all hidden away That might also be having an effect Undecided Smiley
Also checkout the "restrictive" German look Airbox setup - a VERY well made piece of kit from GWD but not to my taste  Wink
Rob DVKK
« Reply #9 on: October 01, 2009, 04:14:03 am »
I ran the old style scat 1:25's in my 1914 with both a 120 and 125 engle cam. Think they measured out at about 1:38.  The heads were 42 x 37.5 with a port job.  Never had any problems. Ran bugpack doubles. All steal 54 sunroof and a stock gear box ran consistant 14.0-'s with that combo.
Also drove from Vancouver to Seattle a couple times a year with that combo.
« Reply #10 on: October 01, 2009, 10:38:48 am »
Hmmmmm what pushrods did you run  Huh Smiley
« Reply #11 on: October 01, 2009, 10:48:24 am »
sounds like a good engine. but judging from the thick washer under the rocker shaft i don't think the valve geometry is correct. with swivel feet adjusters, stock rockers on a w120 you shouldn't have to shim it that high.
and like what has been said, 1.25 rockers are often more like 1.3/1.35. i'd have a look at the valve geometry as is unless you can find good rockers. and perhaps up the venturi size like zach mentioned.
that airbox looks expensive, but unless there's some scoops in the decklid where is it supposed to suck in the air Huh
JS
« Reply #12 on: October 01, 2009, 11:00:54 am »
I do love that spark plug wire "separator"...  Cheesy
Signature.
« Reply #13 on: October 01, 2009, 11:16:55 am »
Oi don't be mean  Wink Smiley But you are Right  Smiley
Rob DVKK
« Reply #14 on: October 01, 2009, 17:12:32 pm »
Pretty sure they were bugpack as well - chromoly with hardened tips.
Still using the same rockers in the 2275 I'm running right now. Switched the cam out to an 86b though - do miss the on/off of the 125 with those rockers. Ran nice and calm until you ran it up over 4500. Then it was a different story - really worked with my heads once the revs got up there.
