September 22, 2026, 03:39:23 am
| | |-+  Super/Stock all motor racing at the Hot VW's Drag Day, October 25th, 2009
Author Topic: Super/Stock all motor racing at the Hot VW's Drag Day, October 25th, 2009  (Read 4060 times)
RUN IT
« on: October 02, 2009, 16:08:43 pm »
After week's of planning and negotiating, I am excited to announce that on October 25th at the world famous VW Drag Day at Irwindale Raceway, head's up "all motor" racing returns to the Southern California. Many of your favorite racer's have already made plans to compete and anyone interested in running in what is sure to be a highly competetive event are invited to join in on the fun.
Some of the sponsor's for this historic event include, BugPack Products(http://www.bugpack.com/), Geer's Engineering(http://www.geersengineering.com/), Head's Up Performance(http://heads-up-performance.com/index.php?option=com_frontpage&Itemid=1), Type 1 Restoration's of Arizona, Dominator Engineering chassis' and fabrication from Monrovia CA. and LAT Lubricant's(http://lubeatech.com/) as well as D&A racing HP engine's.
The basic rules revolve around stock style intake flange cylinder heads with cars running at 12lbs. per CI. restricted to .625 lift and a 44mm carburator venturi. If your car fit's this basic outline and you might want to run contact me for the full set of rule's. Since this is the inaugural event for this class, the rules are simple to allow many but well restricted in an effort to have good side by side racing!!
A big thank you goes out to everybody that has helped to make this happen and I hope we can make
it an event to remember,
Doug Gonzalez
« Reply #1 on: October 02, 2009, 17:43:48 pm »
Hi
This sounds like a good class with rules that makes it not so expensive ! Good luck to you..
Is the weight with driver ?
« Last Edit: October 03, 2009, 07:33:03 am by Udo » Logged
