June 10, 2026, 03:57:41 am
mvptkfjb
Minimum deck?
Topic: Minimum deck? (Read 4673 times)
Minimum deck?
October 05, 2009, 23:18:01 pm »
What is the absolute minumum piston to head clearance you've
successfully
run?
I usually look for .040" as minimum, but considering the possibility of less for a limited time.
82 X 94, carrillo rods, compression in the 10.5-11:1 range.
Re: Minimum deck?
October 06, 2009, 01:43:04 am »
I was told by a good source that no less than .040. I've ran a ZERO deck with a .040 copper head gasket with no problem on my 2303 a few years back.
Re: Minimum deck?
October 06, 2009, 04:36:18 am »
There's no one-size-fits-all for the minimum deck height you can run. The min depends on many factors. Stroke, rod journal, main journal, connecting rods, cylinders are all just a few of what determines how tight you can go.
A 69 stroke VW journal can take much tighter DH than an 84 stroke Chevy journal crank.
Using Pauter aluminium rods? You'll never get away with 1mm of DH.
Re: Minimum deck?
October 06, 2009, 04:38:55 am »
Bruce,
I agree completely ...
The stroke is 82 (Okrasa) with Carrillo rods, 5.352".
Re: Minimum deck?
October 06, 2009, 04:43:44 am »
What are your journals? Chevy? VW?
Mains: Type 1 or 4?
Re: Minimum deck?
October 06, 2009, 15:00:47 pm »
It has type 1 mains, Bruce.
Good components, but old school as they say; Okrasa, Berg, Fumio and the like.
Think I'll stick the .040" rule ...
58vw
Re: Minimum deck?
October 06, 2009, 22:55:10 pm »
new school tom new school....u know what im talking about.....
www.4inbore.com
Angleflows...order them now
