October 12, 2026, 17:47:43 pm
| | |-+  scat engine case
Author Topic: scat engine case  (Read 8970 times)
jr59
« on: October 08, 2009, 11:43:52 am »
well who can give me more info to me.
It's time for us to go with bigger cc engine so thinking of this case to make the work!
I know that a aloy case from CB or othe can easely handle the job but I like this case so... Grin Grin
I sent a mail to Scat with no answer so I even don't know if I can find one new!
The MAIN info I need is about how does it come out of the box (bearing line good or wrong(like so many now),oil gallery ...
I can imagine the normal work to do on case but I don't want to waste time buying totaly unuseable parts!(I already had bad surprise with hi po parts from brand name !!)
hope getting info Wink Wink
cheer
 JR
« Reply #1 on: October 08, 2009, 11:55:14 am »
I think you will never find a case that is ok in the main bearing line . Most work like they are , but no one has the correct diameter and is straigth . I had one alumium case that must get bored for 1. oversize on the shoulder bearing, it was too big .
I had one autolines case fro a customer that was ok...
« Reply #2 on: October 08, 2009, 12:47:09 pm »
JR, Bernard Newbury uses Scat cased motors. I know Jack Sachette builds the engines for Bernie, so it might be worth e-mailing Jack. Wink
jr59
« Reply #3 on: October 08, 2009, 15:33:53 pm »
Thanks for the info!
udo yes we actually have same problem in our facility !!
But in this world  I have 2 really good one  Grin Grin:
my old BERG one purchased in 1995
and the one we use now comming from mike lawless wich is a CB panzer case .thinking it was really  cheked before any use...
About athe scat one,it would be a shame to buy such part and line bore it before any work on it Angry Angry..but I think it will be the thing to do
cheer
 JR
« Reply #4 on: October 08, 2009, 20:07:34 pm »
Most you can use the case as it is , some minor difference in boring is ok . I messure all new cases and give the bad ones back . Or i pull of the 8 mm  pins , make it straight , install oversize pins and shuffle pin the case . a lot of work but it is worth the work
« Reply #5 on: October 08, 2009, 20:10:46 pm »
Scat currentley dont have any available so you need to look for a good used one,
cheers richie,uk
sven
« Reply #6 on: October 08, 2009, 20:25:27 pm »
We line bored mine to!!
bang
« Reply #7 on: October 08, 2009, 21:11:16 pm »
use a wbx for a 2779 oxy. i run one with dpr 86 crank and 4" vanolia pistons and jpm ms230 in 4"
but if it is for full out racin i would use a set og autocraft heads..
some of my parts is for sale so pm me for more info.
just went home from us and i know roger crawfor has a new buils scat engine in his workshop for sale..
jr59
« Reply #8 on: October 12, 2009, 15:21:42 pm »
hi,
well thanks for the advice.
I will try to mail or call crawford for that(thanks bang!)
But if anyone know about a good one,well just tell us
cheer
 JR
« Reply #9 on: October 12, 2009, 19:11:39 pm »
hi,
cheer
 JR
I have seen a couple on the amba recently and autocraft ones as well
cheers richie,uk
