September 22, 2026, 21:24:55 pm
| | |-+  What to chose?? 16v Battery
Author Topic: What to chose?? 16v Battery  (Read 5057 times)
Devils speedshop
« on: October 13, 2009, 09:34:01 am »
Hey
Can someone help me to chose a 16v battery for my racecar:
I been looking at this battery from kinetik, I think it cool that there is 12v and 16v in the same battery so you don't need the step down modul if you have some instrument the can only take 12v. But the weight is a minus..
http://www.jegs.com/i/Kinetik-Racing/577/KR2416/10002/-1
Also this from PowerMaster S-1000 a light weight battery
http://www.jegs.com/p/Powermaster/Powermaster-XS-Power-Batteries/795651/10002/-1
I don't want a small battery that can just start the car a few times..
I have the 16v alternator from Shawn Geers on the car.
Hope someone can help me.
Christian
« Last Edit: October 13, 2009, 09:36:55 am by Devils speedshop » Logged
Team Angora Racing
Phone: +45 21291280
AngoraRacing@gmail.com
Christian Ulberg
Denmark
« Reply #1 on: October 13, 2009, 10:29:13 am »
Is money a issue with todays exchange rate?  Smiley c/p from a earlier post;
The dream battery;
- 12.8V (12 volt terminal) - 17.2V (16 volt terminal)
- Cranking Amps (CA) 1225 amps
- Cold Cranking Amps (CCA) 605 amps
- Reserve Capacity (RC) 65 minutes
- Capacity 29 Ah
-Terminal Type  SAE BRASS
- Working Temperature -22?F to 140?F
- Dimensions 8" long x 5-1/4" wide x 7-1/2" high (not including terminals)
- Weight 11 pounds
- $ 2400
http://thevbattery.com/cart/index.php?main_page=product_info&cPath=0&products_id=230
Devils speedshop
« Reply #2 on: October 13, 2009, 10:45:42 am »
Im looking for something a bit cheaper...
Christian
Team Angora Racing
Phone: +45 21291280
Christian Ulberg
Denmark
