August 13, 2026, 17:35:31 pm
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| |-+  Wanted
| | |-+  Where the hell can I buy 24mm hex bar from!!!!!!
Author Topic: Where the hell can I buy 24mm hex bar from!!!!!!  (Read 6550 times)
« on: October 13, 2009, 15:37:34 pm »
I have been searching the net for AGES and I can't find a supplier for 24mm Hex Bar - Can anyone help Huh Huh Huh
jick
« Reply #1 on: October 13, 2009, 15:51:26 pm »
this place seems to have it in 1" section in Aluminium.....you need to scroll down a few pages.....i know its not quite 24mm but it might be a start?
http://www.arenastock.co.uk/Arenastock-catalogue-2005.pdf
cheers dude....Jick,
what do you need it for?
just had another look......they do a 24mm in mild steel and stainless too..... Wink
« Last Edit: October 13, 2009, 18:25:30 pm by jick » Logged
« Reply #2 on: October 13, 2009, 21:18:01 pm »
COOL cheers dude - I only just saw your reply  Smiley
This for a Patenten'd Monkiboy mod I am doing for my friends 68 http://cal-look.no/lounge/index.php/topic,7573.0.html  Wink
I had this idea ages ago and now I have the chance to try it out - Basiclly it has ALWAYS annoyed my how there is NO place to put a proper spanner on the Tracking arms on a vw so I have drawn up some plans for a small 40mm long section of 24mm hex bar that I will bore out internally to 19mm (diameter of tracking arms) then slide it onto the arms then run a bead of weld round each end (then dress the weld & paint)
So now you have a nice area where you can use a 24mm spanner to adjust your tracking - maybe its a little "overkill" but I just think it will help in the future  Smiley
I am also gonna do the same to the 2 framehorn bars for the rear truss bar so that can also be adjusted/preloaded easyily  Smiley
« Last Edit: October 14, 2009, 03:00:49 am by monkiboy » Logged
Fritter
« Reply #3 on: October 14, 2009, 04:18:13 am »
http://www.onlinemetals.com/merchant.cfm?id=745&showunits=mm&step=2&sortby=od&top_cat=60
Mike F.
'64 Indigo Blue sunroof Bug
jick
« Reply #4 on: October 14, 2009, 09:27:18 am »
thats a good idea dude, i just replaced all the track rod ends on my '59 so i know exactly what you mean.
AutoManics
Race car fabricator - 07780 874435.
« Reply #5 on: October 14, 2009, 11:22:16 am »
I have done this mod before on various vehicles, easiest way is to buy nuts in the size you want and bore the middle out to the right size, looks tidy too! Smiley
You can see them in place here on my 4 bars.
« Last Edit: October 14, 2009, 11:25:07 am by AutoManics » Logged
Type 34 Ghia - 8.92@150mph.
www.automanics.com
« Reply #6 on: October 14, 2009, 12:03:56 pm »
Hey thats not a bad idea about the Nuts but I have 4 cars to do in total and I want to make the spanner area slightly bigger than just a nuts width, Thanks for the pic though:)
