September 22, 2026, 19:36:43 pm
What thickness lexan for flush fit?
Topic: What thickness lexan for flush fit? (Read 5848 times)
jamiep_jamiep
October 14, 2009, 09:35:37 am »
And whats the preferred mounting method? Have heard various ways, mounting them on allow blocks, rivetted direct to the body etc.
Any info would be useful!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Woodentop
Re: What thickness lexan for flush fit?
October 14, 2009, 10:44:20 am »
Hi KB
For flush fit windows, 3mm seems to be the way to go, i believe the outside edges are thinned down to suit the curve of the body of the car, edges are masked and painted black, then riveted on. although there may also be a way of using tiny screws, someone on here will be able to advise better how all this is done.
I would always recommend using the "Margard" version of Lexan though, its the scratch resisitant one, bit more expensive but worth every penny of the extra.
As a note, maybe use an acrylic based paint and
always
paint an offcut first and leave it a while to check the reaction, Lexan as with most plastics is alergic to solvents.
Hope it helps
Woodentop
AutoManics
Race car fabricator - 07780 874435.
October 14, 2009, 11:28:12 am »
I use 4mm stainless button heads to fix in place, much easier to remove if you need to, the paint model shops sell for R/C car bodies is perfect for painting the edges.
Type 34 Ghia - 8.92@150mph.
www.automanics.com
jamiep_jamiep
October 16, 2009, 08:13:39 am »
Cheers guys
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
SteveW
October 16, 2009, 17:59:23 pm »
Paul (AKA Woodentop) sells the best lexan
We have the Margard lexan all round and its great stuff!
Direct Plastics - 0845 838 3318
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
