September 22, 2026, 08:29:26 am
| | |-+  Konis
Pages: 1 [2] Print
Author Topic: Konis  (Read 19748 times)
« Reply #30 on: October 16, 2009, 21:25:27 pm »
LPI-got some Setrab bits from those guys.  They were easy to deal with.  Good thing I didn't tell them I know Ratto...   Lips Sealed
Grin Grin
what's up there, Mike? Jack driving the 2110 yet? Shocked
« Reply #31 on: October 16, 2009, 21:50:44 pm »
Not yet...PM'd ya for thread cleanliness.   Tongue
sofaking
« Reply #32 on: October 17, 2009, 01:24:19 am »
Just ordered a pair from jegs.com $253.98 shipped!
« Reply #33 on: October 17, 2009, 09:11:09 am »
how do spax compare to koni's?
i have a deal waiting on some spax, but if they are not up to par i might reconsider them.
btw KYB, they are just not good on any off my type3's. at first i thought they were OK, but the handling did not improve at all.
« Reply #34 on: October 29, 2009, 14:54:39 pm »
What about Bilsteins? They are in the simillar price range as Konis...
Stephan32
« Reply #35 on: October 29, 2009, 15:23:07 pm »
Hi Guys,
I run red Konis on the front ( special shortened type for lowered beam  available at CSP)
and Bilstein Rally at the rear ( IRS/with heavy TYPIV engine ).
With a TYPE I engine the red ones are ok.
That combined with a 14mm Sway bar at the front and 19 mm Sway a way bar at the rear gives a second to none
suspension that takes you around corners like an early Porsche at the same time with fantastic ride comfort.
I also had KYB and yellow Konis, They where way too stiff.
Also the Bilsteins at the rear are great for the 1/4Mile.
My car is transferred from 1/4 Mile to road just by changing over shocks and wheels.
The only downside is the gear box is no longer good for Autobahn cruising, but a lot of fun
in Town and the open country  Cool
For me Konis are the way to go!
Knowing that a lot of the cars here are Cal-Lookers and 1/4 Mile racers you may take no notice of my written word!
Cheerio    Grin
« Reply #36 on: October 29, 2009, 17:26:55 pm »
Where did you get a 14mm front sway bar??
Dominick Luppino
« Reply #37 on: October 29, 2009, 19:44:25 pm »
Also, try this company,
http://www.eshocks.com/bil_veh.asp?Model_Index=2Q45&Manf=All&SubChar=Q
« Reply #38 on: October 29, 2009, 20:11:54 pm »
is that the stock size? I think the holes in the bushes are 13mm
« Reply #39 on: October 29, 2009, 21:25:24 pm »
I believe that I had a stock factory 14 mm front sway bar on my Thing. The one on the beetle is thinner and uses other bushes.
« Reply #40 on: October 29, 2009, 22:03:44 pm »
Stock Beetle is 10mm. I had no idea the Thing used a 14mm bar, that's good to know Wink
Brandon Sinclair
« Reply #41 on: October 29, 2009, 23:42:56 pm »
Yeah the Thing ones are thicker but the sway bar bushings are NLA so you have to modify some urethane ones.
« Reply #42 on: October 29, 2009, 23:54:44 pm »
or you can drill stock rubber ones. I've done that on countless cars to run sway a way
« Reply #43 on: October 30, 2009, 00:56:02 am »
yep just drill out rubber or urethane bushings to the correct size. Nice feature of the Thing sway bar is that it is more rolled upwards, so is close in shape to Sway-A-Way front swaybar for lowered balljoint beam. It was made like that to maintain clearance for offroading and on lowered balljoint beam it doesn´t come close to the ground.
I suppose that now the demand for Thing swaybars will skyrocket:-)
Stephan32
« Reply #44 on: October 31, 2009, 16:14:49 pm »
In the 90's Eibach ( I think ) used to make them they where power coated blood red items !
But correct VW 181/Thing uses a 14mm sway bar!
About a year ago I saw a few for sale NOS or still produced??
Cheers Stephan
Drų
« Reply #45 on: November 01, 2009, 01:21:43 am »
I bought from CSP 4 adjustable red Koni.
They have totally changed the handling; more precision making curves and comfort more than acceptable, enough to justify money spent.
Really suggested.
Pages: 1 [2] Print
