August 13, 2026, 01:56:52 am
Kennedy clutch problem.....!!!??
Topic: Kennedy clutch problem.....!!!?? (Read 16955 times)
FDK/mrpedrini
October 17, 2009, 20:31:47 pm »
Hi fellow loungers...
Today I put my fresh build 2017cc engine in my bug... Engine is assemled with only new parts, and also a new Kennedy stage 2 pressure plate.... when mounting to the flywheel i noticed that the diagraph fingers pointed somewhat to the inside, and when assembled on the gearbox (in the car) I cant feel any pressure at the clutch pedal , even after adjusting clutch cable!!!
Could this be a failure in production, or could there be another explaination?? Maby there is someone who dealed with the same problem...
Dennis...
Sander/DVK
Re: Kennedy clutch problem.....!!!??
October 17, 2009, 21:31:17 pm »
Hi Dennis, did you remove the ring of the pressure plate? Maybe you have a late model tranny, and you need the extra ring.
Cheers,
Sander
Edit, you can see it on this picture:
Last Edit: October 17, 2009, 21:33:26 pm by Sander/DVK
October 17, 2009, 21:41:18 pm »
i think that the plate is preloaded too much by bolting the plate on the flywheel. losen the bolts and you will see the 'fingers' move outwards. this is either due to a too tick plate or maybe the possition of the plate/ flywheel. check the depth you have on the flywheel.
FDK/mrpedrini
October 18, 2009, 19:24:59 pm »
Quote from: Sander/DVK on October 17, 2009, 21:31:17 pm
Cheers,
Sander
Hi Sander, the ring is out....That ring is for a non guided clutchbearig.... i drive a guided one. Geers... D
FDK/mrpedrini
October 18, 2009, 19:28:24 pm »
Quote from: nicolas on October 17, 2009, 21:41:18 pm
Sounds reasonable....next week end i'm gonna pull out the engine again and take a closer look... And i will order a second Kennedy...just in case..
Kind regards....Dennis
FDK/mrpedrini
October 21, 2009, 17:55:25 pm »
Today i get the day off, so i dicided to pull out the engine again... took off the kennedy and put an original LUK clutch kit onto it....Put engine back into the car...and.......Same problem..No pressure on the clutch pedal... Engine out again and take LUK off.... Messured Flywheel dept from friction surface 21mm..... messured an original flywheel 22mm dept!!!!! put 1mm shims between pressure plate and flywheel....looking good. Engine back in the car... GOT PRESSURE!!!!!!!!! Next thing to do is pull the engine out (again) and take flywheel off to some machineguy to take 1mm off......then i'll be good...
Regards, Dennis....
October 21, 2009, 18:31:53 pm »
I would check the differences in thickness of the friction plates. Never had problems with Kennedy's since they are all german anyway. Just my 2 cents.
FDK/mrpedrini
October 21, 2009, 18:45:30 pm »
Quote from: FDK/Hurry on October 21, 2009, 18:31:53 pm
Hey Harry, I did messured the thickness of 2 different plates. Got one new DAIKEN disc (without springs) and got one new LUK friction plate (from my 1600 engine) , both messure the same thickness..... Also mounted the Kennedy and the DAIKEN to my 1600 flywheel... NO PROBLEM.... guess the chromoly SCAT flywheel isn't machined well like a VW pizza....
Have a nice eve, Professor....
October 21, 2009, 19:09:51 pm »
I didn't know you had a new flywheel..... Did you compare it with a (used) german one ?
FDK/mrpedrini
October 21, 2009, 21:27:07 pm »
Quote from: FDK/Hurry on October 21, 2009, 19:09:51 pm
Jep, did compare it with 2 german ones. The vw flywheels messure both 22mm depth (messured from the surface where the friction material grabs on and the stair where the pressure plate gets mounted. the Scat flywheel I bought has a depth from 21mm..... so it isn't cut deep enough. Looks like a litle bit, but apperently enough to not let the diafragma get enough preload..... And that counts both for the Kennedy stage 2 (wich seems perfecly alright) and a stock LUK clutch kit.. So what do we learn? buy the best and buy VW!!!
October 22, 2009, 16:40:52 pm »
It is not a problem to shim it out to correct the problem,it should be 21.7mm deep,you can just use washers or similar under the pressure plate where the bolts pass through
cheers richie,uk
FDK/mrpedrini
October 22, 2009, 21:21:12 pm »
Quote from: richie,uk on October 22, 2009, 16:40:52 pm
cheers richie,uk
Hey Richie, that's what i've did right now using some normal M8 closed plates.... can I leave them in or should I replace them with something that fills the whole area between pressure plate and flywheel? (I'm a bit worried that the pressure plate doesn't contact like it normally would do)
Thanks anyway....Dennis
October 23, 2009, 06:16:06 am »
Yes that will be fine,I have run plenty of clutches set up like this
cheers richie,uk
Jason Foster
7.69 87mph 12.35 106 mph
November 09, 2009, 05:57:55 am »
Quote from: richie,uk on October 23, 2009, 06:16:06 am
cheers richie,uk
Well there's your problem!!! It's the extra weight of those washers causing all those wheelies! You really don't need bars.
Sander/DVK
November 15, 2009, 18:26:48 pm »
Hey Dennis, how are your engine doing now? Is it running yet?
FDK/mrpedrini
November 15, 2009, 23:37:32 pm »
Quote from: Sander/DVK on November 15, 2009, 18:26:48 pm
Hi Sander, engine is running verry well
. clutch problem solved.... All i need now is some good weather to take the car out.....and some cashflow to buy a decent tranny
Sander/DVK
November 16, 2009, 23:12:59 pm »
Cool! Do you have a little movie to share?
FDK/mrpedrini
November 17, 2009, 19:06:45 pm »
Quote from: Sander/DVK on November 16, 2009, 23:12:59 pm
Not jet, still wanted to do that.....and when i have one i hope i can put it on the lounge....it's even difficult to post pict's to me
....have some pictures posted on
www.rayfdk.blogspot.com
How is your car and engine doing Sander?? grtz D
November 17, 2009, 22:27:08 pm »
Quote from: FDK/mrpedrini on November 17, 2009, 19:06:45 pm
He Dennis how are you doing, cool pictures on there, engine looks very good. how is it running.
Say hi to madman Ray for me...
Kind Regards Edgar
Sander/DVK
November 18, 2009, 00:01:52 am »
Mr speedwell have made a Sticky how to post pictures. You can do it
http://cal-look.no/lounge/index.php/topic,3632.0.html
My car and engine are gone.. a while ago. I have started on a new project. I will post some update's soon on the dutch callook forum.
FDK/mrpedrini
November 18, 2009, 18:16:02 pm »
Quote from: Eddie on November 17, 2009, 22:27:08 pm
Kind Regards Edgar
heey Mr Ed
I'm doing fine...only have to spend to much time on non vw stuff
.. Engine runs great, revs till 7500 rpm, wich is supprising because i build it on the mild side... not the fastest engine i believe....but hot enough to scare some plastic bombers
.. How are you and the type 4 doing?? nice to hear from you!!!
FDK/mrpedrini
November 18, 2009, 18:18:45 pm »
Quote from: Sander/DVK on November 18, 2009, 00:01:52 am
Thnx Sander, ill give it a try...
What kind off car are you working on??....(i'll check the dutch forum) grts D
November 18, 2009, 22:38:39 pm »
Quote from: FDK/mrpedrini on November 18, 2009, 18:16:02 pm
Kind Regards Edgar
heey Mr Ed
Good to hear engine is running great.
Typ 4 is comming along ok, still waiting on some small parts but have ''try fitted'' it and everything seems to fit.
I have some pictures, will post them on here soon.
Kind Regards Edgar
