September 10, 2026, 12:14:46 pm
Bad Habit
The best rear end
Topic: The best rear end (Read 6333 times)
SPRasmussen
ET 10,54 - 197,65 at SCC 2011
The best rear end
October 23, 2009, 09:40:04 am »
Last Edit: October 26, 2009, 06:14:16 am by SPRasmussen
Søren Rasmussen
Owner of The Ultra Rat
www.TeamAngoraRacing.dk
max2919
Re: The best rear end
October 23, 2009, 21:14:47 pm »
Backhalf it with ladderbars and coilovers or drop the body over a real tube race chassis....
Go to
www.ronlummusracing.com
for more info.
VW 57 Ghia RLR 2919cc TURBO!
Porsche 356A Coupe replika.
October 26, 2009, 15:06:43 pm »
I think it is quite obvious that your rear end is a bit on the soft side. It is not easy to get any grip when it so saggy. And I`m talking about your car;
Eric Justus
October 27, 2009, 05:38:01 am »
How much hp are you playing with? some 28mm torsion bars, adjustable spring plates, QA-1 shocks and limit straps will fix ya right up. If you want a quick fix, throw some bus snubbers on there...that should help out a bit and rather cheap.
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
October 27, 2009, 17:32:59 pm »
It is too low to begin with... for good traction off the line, isn't it best to have a touch of positive camber when static?
