October 13, 2026, 06:13:01 am
| | |-+  Straight cut gears or not?
Author Topic: Straight cut gears or not?  (Read 8205 times)
fahrvergnugen
« on: November 03, 2009, 22:10:31 pm »
Hi Guy's
I am collecting parts to build a 2,4ltr Oxyboxer. Cool
Here's the plan;
WBX case....check
Porsche 100mm nickies....check
2.1 crank (76,4mm)....check
heads (trying to use split-ports)....check
Scat 5.5" H-beams with 23mm small-end....check (rod ratio 1.83:1)
Turbo....check (probably to small)
The next parts I need are cam, cam gears and lifters. should I use straight cut?, must I buy cam and lifters as a combo?
Paul.
« Last Edit: November 04, 2009, 12:21:22 pm by fahrvergnugen » Logged
« Reply #1 on: November 04, 2009, 04:10:09 am »
Straight cuts are only really needed when you go to chevy size valve springs,you can mix cam and lifter manufacture but it is better to source them from the same companie unless you are sure they are compatible
cheers richie,uk
fahrvergnugen
« Reply #2 on: November 04, 2009, 12:21:07 pm »
cheers richie,uk
Thanks Richie,
Is it better (when not needed) to use normal gears, or is straight cut always useable?
Paul.
« Reply #3 on: November 04, 2009, 15:58:10 pm »
Is it better (when not needed) to use normal gears,....
Yes because the $$$ you save on gears could be spent on something that actually makes you more hp.
fahrvergnugen
« Reply #4 on: November 04, 2009, 20:33:02 pm »
Good point. Cheesy
Bewitched666
Bewitched
« Reply #5 on: November 05, 2009, 14:55:07 pm »
Lot of people buy straights becoz they have been told the noise is great to hear Cool
Fast vw beetle's rule
glenn
« Reply #6 on: November 05, 2009, 15:03:40 pm »
It gets old fast.
Two years ago I split the case for a friend to change the gears... i was sick of the noise.g
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #7 on: November 05, 2009, 15:55:26 pm »
Or they can't be bothered by opening the case to change the cam bearings because the cam bearing thrusts are gone. Which happen much faster depending on spring pressure (needed for whatever reason)
« Reply #8 on: November 05, 2009, 16:06:48 pm »
Ricers!
tikimadness
« Reply #9 on: November 05, 2009, 18:36:17 pm »
Okay so I am still thinking about using the straightcuts cause I think I need some real spring pressure as I want to run a lot of boost.Is it true that when boost increases the springpressure should be more to keep the valves from floating?
Sorry to highjack your thread Paul Wink
Michael
NIDGAFWYT
« Reply #10 on: November 05, 2009, 19:21:55 pm »
Michael
Yes,I have found that boost affects the spring pressure needed,for your engine you will need enough spring pressure to need dual thrust cam bearings &straight cut gears
cheers richie,uk
tikimadness
« Reply #11 on: November 05, 2009, 19:34:34 pm »
Michael
cheers richie,uk
Thanks hoping to build up some pressure soon Wink
MIchael
NIDGAFWYT
