September 28, 2026, 20:18:34 pm
Nostalgia you win again!
6
7
Topic: Nostalgia you win again! (Read 244381 times)
Re: Nostalgia you win again!
Reply #180 on:
November 26, 2016, 16:25:14 pm »
Thanks Richie!
Reply #181 on:
November 28, 2016, 13:08:53 pm »
First I fiddled around with the new fender, and got it to fit the car much better.
Then it was time to get those nice weather sealing strips on the front again. An amazing amount on rust behind them, but now they are covered with more of that Volvo weld primer.
Let's hope they hold up another 40 years. First a nice coating of weld primer
In the end it came out ok
Last Edit: February 12, 2021, 09:51:21 am by Jon
Reply #182 on:
November 28, 2016, 13:16:25 pm »
Nice work Jon and it is indeed good to see that light blue color being used
-BB-
sonic
Reply #183 on:
November 28, 2016, 20:39:17 pm »
Great work Jon , the effort you put in to preserve the -03
Rgs
Reply #184 on:
November 29, 2016, 12:08:20 pm »
Thanks BB and Sonic!
Again a quick spread of Volvo weld primer:
A little gentle shaping of the piece and it was time to break out the spot welder.
Quite stock looking
With a quick primer it looks stock, but without the rust...
Last Edit: February 12, 2021, 09:53:40 am by Jon
Gwar72
Reply #185 on:
December 16, 2016, 17:06:10 pm »
Quote from: Jon on November 22, 2016, 17:05:48 pm
Thanks Gwar72
Moving right along on the car, to get the best result I brought the car over to the local body shop and we used their state of the art spotwelder
Hi Jon,
Have you any pictures on how you peeled back the outer seam when you put in the new front quarter in?? I think I'm going to have to replace both of mine and thought that if I cut 1cm vertically forward in front along seam I wouldn't have to mess with peeling it back and reforming? (I hope that makes sense?) One panel had been used (spot welded on the lip, so don't want to use that bit) Cheers
Last Edit: February 12, 2021, 10:04:56 am by Jon
Reply #186 on:
January 16, 2017, 11:08:26 am »
Hi Gwar72,
I started out cutting the rail just above the panel, so I didn't need to open all of it. First i pried it open with a sharp screwdriver in the bottom, and then I used a home made tool to bring the lip up to 90° from where it started. The tool is the end of a driveshaft with a grove in it that goes from a point in a smooth curve up to a flat shape.
And after the job is done I just tapped it back down again with light taps.
Last Edit: February 12, 2021, 10:05:38 am by Jon
Reply #187 on:
January 16, 2017, 16:39:15 pm »
Here are some pics from the process on the other side, first opening:
Cleaning
After sandblasting primering the lip was closed again
Done
Last Edit: February 12, 2021, 10:07:35 am by Jon
Gwar72
Reply #188 on:
January 17, 2017, 11:58:25 am »
Brill, Cheers
Is the wing spot welded to lip as well or just pinned behind fold?
Tim
Reply #189 on:
January 17, 2017, 12:26:49 pm »
Next I moved on to the "new" driver side fender. It had been treated to a sickening thick layer of spray filler. And under it all... rust!
Had a hard time removing it around the bucket, so I decided to pop it out.
Didn't regret that
Cleaning up
And I primered everything and welded it back in again
Last Edit: February 12, 2021, 10:12:55 am by Jon
Reply #190 on:
January 17, 2017, 12:29:31 pm »
Quote from: Gwar72 on January 17, 2017, 11:58:25 am
Brill, Cheers
Tim
It's spot welded every 40 mill or so, you can see the stock welds in the second photo.
Reply #191 on:
January 17, 2017, 12:40:43 pm »
Then it was back on the doors, in 75 VW changed out the mounting system for the window lifts. I'm still going with one-piece windows so I need to be able to use the older mounting to be able to fit the double supported type from 68(?)
First I welded in a piece from a older door
Then I cleaned up a older bracket
And spot welded it in.
And then the doors were done.
Last Edit: February 12, 2021, 10:23:37 am by Jon
Gwar72
Reply #192 on:
January 17, 2017, 16:19:19 pm »
Quote from: Jon on January 17, 2017, 12:29:31 pm
Brill, Cheers
Tim
Cheers Jon :-)
Reply #193 on:
January 17, 2017, 16:25:11 pm »
I started restoring another hood for the car. Had to fix the front part of the hood, and exercise my TIG welding skills... or lack there of.
And after welding
I had to remove the hood handle to, and while I generally liked my old solution I decided to reinforce the hood on the inside.
And then weld that to the hood
Last Edit: February 12, 2021, 10:26:08 am by Jon
Reply #194 on:
January 17, 2017, 16:34:51 pm »
The final little part of changing the front quarter panel was to braze up the gap between the the new panel and the cowl like original.
I got my friend Atle to do the job as he is a highly skilled TIG welder.
Came out great in the end.
Last Edit: February 12, 2021, 10:28:30 am by Jon
Reply #195 on:
January 17, 2017, 16:52:24 pm »
Had to repair the bumper mount, I had a professional fix it back when I was sixteen (didn't have the guts to do it myself)
He made a mess of it in my eyes.
There was nothing really wrong with the part, so I cut it of cleaned it up and welded back in the right way and in the right place.
In the end it came out ok and I got to try the new removable back apron.
Last Edit: February 12, 2021, 10:33:41 am by Jon
Reply #196 on:
January 18, 2017, 11:03:29 am »
One of the things I have been worrying about on this project is the roof gutter rust. I know it comes form the inside of the gutter but I have feared to go inside in the past.
But there needs to be a first time for everything.
Here we go
Under way, rust starts falling out from the gutter as it's opened
It's nasty in there!
Rust from start to end, ready to pop out when the paint is on
Open, now it's time to clean
Half way thru sand blasting the snot out of it...
Then the light coat of primer it never received at the factory
Then a little inotech sealer to fill any potential gap once closed.
Then it was time to tap it right back
Time to clean up the inotech excess
After cleaning up
Came out very nice in the end, won't spend another minute thinking about this problem... except the time it's going to take med to do the other side. ;-)
Last Edit: February 12, 2021, 12:10:59 pm by Jon
Steve67
Reply #197 on:
January 18, 2017, 16:35:20 pm »
great work!
what tools did you use for opening and closing it, the result looks awesome
Reply #198 on:
January 18, 2017, 22:37:02 pm »
Thanks Steven! You see the tool I used to open with in post #186. I used a pen hammer and dolly to close it up.
Reply #199 on:
July 26, 2019, 12:24:05 pm »
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
Nah I think I stick with this one. It seems most of the pictures are gone too... great!
Well, the car is painted and it came out ok, considering I did the bodywork and prep myself.
I have been driving a little with the MOT 1600 cc engine, and that will hopefully change right after SCC.
Here are a few pictures with the "track shoes". [ Attachment: You are not allowed to view attachments ]
Last Edit: July 26, 2019, 13:51:37 pm by Jon
Reply #200 on:
July 27, 2019, 06:36:52 am »
one word: YES!
Reply #201 on:
October 12, 2019, 13:33:16 pm »
Awesome car!!
Reply #202 on:
February 12, 2021, 21:17:00 pm »
Sooo... I have fixed all the broken links so the pictures are back for the time being. And due to a small engine fire I’m back in the paint booth. This gave me the opportunity to clean up and paint the engine bay.
ibg
Reply #203 on:
February 12, 2021, 22:39:23 pm »
a beautiful car, what size wheels and tyres are you running?
Reply #204 on:
February 12, 2021, 22:44:34 pm »
Thanks! The wheels are 8” in the front and 9” in the rear. Tires are 195/50-15" and 225/50-15" in the rear. Stock fenders.
Last Edit: February 13, 2021, 11:15:03 am by Jon
Reply #205 on:
February 13, 2021, 19:59:46 pm »
Quote from: Jon on February 12, 2021, 21:17:00 pm
Wow Jon came out of hibernation
I feel you pain on the engine fire, hope it wasn't to bad
6
7
