September 22, 2026, 09:32:42 am
Head Studs
Topic: Head Studs (Read 4467 times)
Head Studs
November 09, 2009, 20:43:02 pm »
What is considered the limit on stock head studs? Any reason to not to use them on my low compression 1914 build?
Thanks,
Re: Head Studs
November 09, 2009, 22:36:29 pm »
I have used the Berg studs (stock) on my 2303cc W/200HP without no problems at all. Building a motor now with more power with the Berg studs. Basicly they are stock VW studs that have been black oxide. They are very nice. But to answer your question, you should no problem what so ever.
Felix/DFL
Re: Head Studs
November 10, 2009, 21:52:20 pm »
Anyone tryed out the CSP headstuds (M8)
They are just a toch more expensive than orig. VW. But no crom-moly as I understand and coated as the Berg one`s...
Re: Head Studs
November 10, 2009, 21:59:43 pm »
I have not seen those.
Felix/DFL
Re: Head Studs
November 10, 2009, 22:04:55 pm »
here you go:
http://docs.csp-products.com/katalog/?view=45
M8=49€
Last Edit: November 11, 2009, 00:09:18 am by Felix/DFL
Re: Head Studs
November 10, 2009, 23:00:50 pm »
loius,
I used stock 8mm german head studs on my 10.2/1 comp 2332 nitrous engine,ran high tens in the cab with them,broke a couple when I got the tune wrong but they are plenty strong enough
cheers richie,uk
