September 24, 2026, 06:54:55 am
| | |-+  Choosing air corrector jets for Dells?
Author Topic: Choosing air corrector jets for Dells?  (Read 5033 times)
RUSS74GHIA
VWSP163
« on: November 11, 2009, 08:40:48 am »
Hi, does anyone know what size I shoul be looking at?
They're for my 1914 motor. Carbs are 40's with 34mm vents with 142 mains. I've been offered a set of 205s as a striaght swap for my 180s. Does this sound about right, or is there a formula I should be following.
Thanks in advance.
Russ
« Reply #1 on: November 11, 2009, 20:49:18 pm »
the dellorto book says 180 all the time so you might want to hang on to them.
4x ventsize = main
4x 34 = 136 (so 135 will work, or try 140) make sure to have the right e-tubes, mine are wrong and the car runs but could be better
« Reply #2 on: November 11, 2009, 20:52:36 pm »
Do not trade away your 180 air jet holders, they are the only size you need for your carbs.  All others will be wrong.  There's a reason the other guy wants to get rid of his 205s, it's because they are the wrong size.
RUSS74GHIA
VWSP163
« Reply #3 on: November 11, 2009, 21:35:52 pm »
Thanks chaps, I'll hang onto them.
I've also got a set of 135 mains, so I guess these could be reamed out to 138/140 if required
« Reply #4 on: November 11, 2009, 21:38:56 pm »
or try this link for jets.
shipping shouldn't be that much since your in the right country.
http://www.dellorto.co.uk/merchandise/products.asp?CategoryID=2&PartsectionID=51
« Reply #5 on: November 12, 2009, 03:34:26 am »
Have you tried using the 135s?
RUSS74GHIA
VWSP163
« Reply #6 on: November 13, 2009, 00:23:14 am »
Not yet, the motor's rebuild isn't finished, well, I only picked up the mains/big end bearings yesterday. I'm trying to get everything ready so that I can be up and running as soon as the block's finished.
« Reply #7 on: November 13, 2009, 04:11:44 am »
Run the 135s. Then if they prove too small, ream them out.
My engine is quite happy with 135s in my 40DRLAs.
