August 13, 2026, 08:43:17 am
352259 Posts in 28945 Topics by 6923 Members
Latest Member: Lotus67
| | |-+  Getting suspension working
Author Topic: Getting suspension working  (Read 5222 times)
adrian
« on: November 12, 2009, 20:50:02 pm »
Finally made it into the 12s with a best of 12.87@104.  Running m and h DOTs, IRS rear, beam front. 60 foots are around 1,85 - 1,9.
Currently I have dropped spindles on the front, 90/10 shocks, stock rear end barring T2 CVs, 944 stubs. I ran 18lbs in the dots, launched at about 4k.
Am I being realistic in thinking there are a couple of tenths in the 60ft ? 1.6 ish ? Was not really pushing hard in the burnout, just 1st gear. Still needs a lot of tuning work - dyno in a couple of weeks.
Heres a video of it launching <a href="http://www.youtube.com/v/_uhXMB7oxf4" target="_blank">http://www.youtube.com/v/_uhXMB7oxf4</a>
PPRMicke
« Reply #1 on: November 12, 2009, 22:33:10 pm »
What size are you on the torsion bars in the rear?
Ride heights on the car rear?
I often have 1-1.1 / 2 degree angle on the car as a basic setup
Best regard
Michael
adrian
« Reply #2 on: November 13, 2009, 01:15:51 am »
Stock Bars
Axles are about level at rest (probably a bit low)'
I was thinking going back to stock spindles and lifting the rear slightly would help with weight transfer and getting the tyres to stick.
PPRMicke
« Reply #3 on: November 14, 2009, 12:12:38 pm »
Hi
If you watch the video at 0:15 you can see how the car is not moving weight
You may have problems with the clutch to the wheels lose traction
/// Micke
Steve D.
« Reply #4 on: November 14, 2009, 21:03:55 pm »
M&H D.O.T.'s ROCK!  Burn them in second in the waterbox- I usually just go until I can see the smoke in the side view mirror, still probably more than necessary.  Virtually same setup as your car except no 90/10's, just stock shocks and the first time I went out with them the car went mid 1.6's all day at 18psi- just be sure your gearbox is up to the task because these WILL HOOK!
Have fun!
Über Alles
10.77 avg. on pump fuel.
238I
