September 24, 2026, 23:51:18 pm
| | |-+  Distributor drive gear differences
Author Topic: Distributor drive gear differences  (Read 3397 times)
Brandon Sinclair
« on: November 13, 2009, 17:49:31 pm »
I was going through my spare parts and realized I have two different distributor drive gears.  One is for the later model with the longer length gears then the other is a 40hp drive gear with a short gear.  Here is a link to the two I have - the one in the middle and the one on the right.
http://www.thesamba.com/vw/forum/viewtopic.php?t=205262&highlight=distributor+gear+differences
Why were there changes made and can you use the 40hp distributor drive gear with the shorter gears in a rebuild or are the specific to the 40hp drive gear on the crank?
