September 11, 2026, 04:08:40 am
352302 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  Bending Tubing
Author Topic: Bending Tubing  (Read 7442 times)
« on: November 14, 2009, 03:13:37 am »
I need to bend some 1" tubing to make a bumper for my Manx. I don't want to buy a bender just for this little project. Any suggestions?
Thanks,
« Reply #1 on: November 14, 2009, 04:31:08 am »
I`ve never done it myself but I`ve read that if you fill it with sand it won`t kink and you can heat it and bend it around another piece of pipe or something similair for a jig.
« Reply #2 on: November 14, 2009, 04:44:42 am »
Yeah I have been searching the inet and short of buying an expensive bender that seems to be the way to go. I was thinking of maybe using a wooden buck to bend it around. Wonder if you can get it hot enough with map gas. (I really need to invest in an acetylene setup.)
Rocket Ron
It's old school for a reason
« Reply #3 on: November 14, 2009, 07:33:07 am »
I made a balcony to go in front of my first floor double doors than had some 1" bent tube for rails, I heated the ends of the bar up and used a plumbers pipe bender that I hired for the day from the local hire shop, worked a treat
Regards Ron
13.12 @ 101.84
Grooving out on life
yvre
Der Autobahn Scrapers
« Reply #4 on: November 14, 2009, 21:48:32 pm »
A cheap bender will work fine if your fill your tube with sand (and close both ends of course).
Otherwise it will just crush.
Black Sheep
less is more
« Reply #5 on: November 14, 2009, 22:56:31 pm »
Rocket's hit the nail on the head , Heat is the key  Wink
13.03 @ 98mph
Balocco
« Reply #6 on: November 14, 2009, 23:54:59 pm »
What they said. Fill the pipe with sand, plug it and heat it. If you can get it to start turning red with map gas it should work.
Type 1 59 fake split project, Type 1 "US 67", Type 2 61 11W sunroof, Type 2 1961 15W
« Reply #7 on: November 15, 2009, 00:13:13 am »
when i worked restoring Ferarri's/jag/porsches we used to hand make the exhausts/headers using the "Sand Method"
Basiclly you need to do is hammer a piece of 2x2 into the end of the length of pipe/tubing then poor in sand from the other end making sure its well packed in then hammer in another piece of 2x2 into the other end sealing the pipe/tubing
now you need a very very strong heat sourse - then apply to the area needing to be bent and get it REALLY HOT then start to bend it whilst still applying heat - Patients is the key, do it slowly  Wink Smiley
« Reply #8 on: November 15, 2009, 02:25:08 am »
Thanks for the replies. I am still debating if I want to take this project on.
Thanks,
« Reply #9 on: November 15, 2009, 02:32:21 am »
Just what lee said or if you want to by a bender try JD square co.  PS. Use damp wet sand and heat with rosebud and heat inside bend dull red first then while it cools heat outer side of tube, The thicker the wall thickness the smoother the bends. And dont forget to shake tube with a wooden paddle and air hammer to compress sand before corking the second end.
SlingShot
« Reply #10 on: November 15, 2009, 03:38:42 am »
Or just buy a bender.
Will Race For Beer !!!
