September 24, 2026, 23:50:49 pm
VDO senders
Topic: VDO senders (Read 3383 times)
Turtle001
VDO senders
November 18, 2009, 19:56:12 pm »
hey guys -- got a little question -- i do have an VDO oil temp gauge & a VDO oil pres gauge -- the 59er is still in 6V -- can i use the regular vdo senders? or is there a difference between 6V & 12V
http://turtle.skynetblogs.be
henk
Re: VDO senders
November 19, 2009, 00:48:27 am »
hallo,
it normally can be used for 6-12 volt it should stand on the sender as well.
henk!!!
1957lowlight
Philip Steenackers
Re: VDO senders
December 16, 2009, 07:07:51 am »
Hi Turtle,
If these are the gauges you have bought from me. The Pressure one can work with modern VW oil pressure sender, the temperature one will need to be rebuild. Call me if you need help.
