June 11, 2026, 09:16:17 am
352174 Posts in 28911 Topics by 6920 Members
Latest Member: chris41
| | |-+  sourcing type 3 rear shoes and cylinders.
Author Topic: sourcing type 3 rear shoes and cylinders.  (Read 8747 times)
67worshipper
« on: November 21, 2009, 10:18:50 am »
im trying to source type 3 rear brake shoes and wheel cylinders.both cylinders are leaking and its weeped fliud onto the shoes so im replacing both.ive been told that the cylinders are the same as 1303 front drum cylinders.any views on this?looking for a source in the uk.many thanks
vw hot rod heaven
andy M.
« Reply #1 on: November 21, 2009, 18:58:53 pm »
try ssp, they do all the bits you need i believe,
if not then t3d
andy
L.B.C.R.
bluestar
D.A.S member
« Reply #2 on: November 21, 2009, 19:07:43 pm »
type 3 rear brake shoes are same as front 1302/03 .
« Reply #3 on: November 21, 2009, 20:11:54 pm »
yep, very true i think late and early (but after 63) are all the same.
« Reply #4 on: November 21, 2009, 20:44:36 pm »
I used front brake shoes from a drum braked 1302 but they were missing the slot for the metal divider which goes between the shoes. I measured these slots from old shoes and cut them to new shoes with angle grinder.
I also used front cylinders from a 1302. They work perfect with my Ghia dics in the front.
67worshipper
« Reply #5 on: November 21, 2009, 20:51:07 pm »
is the hole in the 1302/3 for the handbrake operation lever and interchangeable then?thanks for your replys Smiley
vw hot rod heaven
181
« Reply #6 on: November 21, 2009, 21:22:48 pm »
yes holes match without problems, they are just lazy to manufacture the slots  Wink
heres a pic for you
« Last Edit: November 21, 2009, 21:26:09 pm by 181 » Logged
« Reply #7 on: November 21, 2009, 22:04:11 pm »
... they are just lazy to manufacture the slots ...
No, you're just too cheap to buy proper Type 3 shoes.  They exist.
« Reply #8 on: November 21, 2009, 22:34:12 pm »
I´m in a part of Europe where access to the NOS or propper stuff is very limited so I used available aftermarket.
benssp
www.callookvw.com
« Reply #9 on: November 21, 2009, 22:59:50 pm »
shoes 311-698-537/ex ATE cylinders 361-611-067/A/ATE Grin
www.vwheritage.com  My Job
YMCA
67worshipper
« Reply #10 on: November 22, 2009, 11:19:54 am »
cheers guys.is those numbers heritage part numbers ben?
vw hot rod heaven
benssp
www.callookvw.com
« Reply #11 on: November 22, 2009, 13:14:09 pm »
of course  Grin
YMCA
« Reply #12 on: November 22, 2009, 14:20:34 pm »
they must exist, but 181 is right. i have ordered the ones for a type3 and got thes without the slot. i forgot about it, but i had to grind it in as well. not sure if there is a quality difference between the two or not, but it wasn't german parts.
and even if you order good quality and you want to make the expense, the dealers end up giving you the same old, non german or quality stuff all over again. i can tell you the mahle bearing-story if someone cares...  Roll Eyes in short it was a super lightweight centerbearing i ended up with and untill i had my engine built by Stevesvwshop, i never saw a real real centerbearing and never thought about it that it was supposed to be so heavy. that is what you get when suppliers always stock cheap parts. but i have learned yet another thing and now i know what to by, the hard question  is where.
like i said i can relate to 181's story. but the brake shoes i had to cut the slot in work really well and have never let me down so far.
67worshipper
« Reply #13 on: November 22, 2009, 15:50:08 pm »
of course  Grin
thankyou
vw hot rod heaven
Brother Lovedub
« Reply #14 on: November 23, 2009, 10:57:08 am »
I got mine from GSF - I'm sure I'll have the part numbers somewhere - will have a look tonight.
« Reply #15 on: November 23, 2009, 17:26:27 pm »
This isn't "the manufacturer being lazy".  It's your supplier sending you the wrong part.  If the manufacturer knew his part could fit another car by simply adding a tiny slot, they would.
67worshipper
« Reply #16 on: November 23, 2009, 19:13:32 pm »
sweet stevie let me know if you can Smiley
vw hot rod heaven
« Reply #17 on: November 23, 2009, 21:00:33 pm »
OK, so apart from the slot what is the difference. material? width?
« Reply #18 on: November 24, 2009, 07:00:52 am »
Nothing.
