November 02, 2026, 18:13:19 pm
Oldschool turbo setup !?!? Any Informations needed !
Topic: Oldschool turbo setup !?!? Any Informations needed ! (Read 50646 times)
Carsten
November 23, 2009, 09:02:39 am »
I am loking for any informations on oldschool turbo setups for a 1600cc engine (maybe go to 1641) , with turbos like schwitzer S1 or Airresearch , with a Weber Carb or Amal (?) , like the ones been made in the 70`s and 80`s . I found some pics , but not very much informations...
So , one other question , are all the Schwitzer S1 turbos the same ?
So any informations and pics and links and so on would be a great help ! Want to build something "period" for my car as a starter and spare engine , before my other car is sold and i can go in the "big business" ;-)
Thanks , Carsten
1969 IRS bug
Fasterbrit
Re: Oldschool turbo setup !?!? Any Informations needed !
November 24, 2009, 09:51:30 am »
Hi there. I have a complete new old stock 1970's Rayjay turbo kit for a 1600 - 1776cc Bug for sale. It has everything you need: n.o.s. Weber carb, nos Rayjay turbo, nos Rayjay wastegate, nos Rayjay inlet manifold, nos VDO gauges, nos boost and oil hoses, nos exhaust header and exhaust pipe. All gaskets, hose clamps are all nos, too.
I will post some pictures soon. Regards, matt
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
November 24, 2009, 10:08:14 am »
I had a play with a turbo a while ago, using my little 1600. I used a turbo off a 1980's Mitsubishi Lancer engine I found in the corner of a friends yard, a homemade header and intake manifold, a 40DCOE Weber and a boost sensitive fuel regulator from CB. I retarded the timing by turning the distributor back and that was the problem - although the advance was correct at higher revs, it was a pig to start and took ages to come onto boost because of the severely retarded timing. Think I ran an 18.4 at 80+mph at a RWYB - previously I'd been running 16.2's at 78ish mph with the same motor with 36 DRLAs. It wasn't until I'd taken it all off that I read an article in VW Trends that said about bending the stops inside an 009 dizzy to stop it advancing at 24degrees without affecting low speed running.
Matt, you want to write down all the specs of that turbo setup, it'll be quite useful!
JamieL
November 24, 2009, 15:36:22 pm »
Boost retard...?
Pah - 1bar + high octane fuel and 32 degrees worked fine on the fugitive!
The Ghia engine also ran up to 32BTDC on pump fuel at over 1bar, but that had a funky cunning ignition map - you gotta love 3D mapping...
Carsten
November 24, 2009, 20:04:19 pm »
Just want to go the oldschool way for playing around a little ;-) Went 11`s and 12`s with the car some years back.... Something bigger will come when (if) my Oldsmobile is sold , if it is not going to the strip next year...Should be able to run on the street like a normal street bug and i want to go a different way than all the others her in germany !
so i hope for more infos and pics....please!!!!!
Greets , Carsten
1969 IRS bug
JamieL
November 24, 2009, 23:07:51 pm »
Hi Carsten,
Sorry for the off-topic remarks, what Neil said just struck a chord...
Anyway - good luck with your search - iirc, they were some references to early turbocharging efforts (and maybe pics) in Bill Fisher's now infamous "How to Hotrod..." book. My copy is stashed away just now, but someone else may have a copy to hand that can help...?
sam P
November 25, 2009, 23:01:27 pm »
Hi Carsten,
Are you looking for a complete 70's-80's turbokit, or are you planning to build something yourself? I would love to see some more pics of nostalgia turbo-engines. I like the idea of the amal carburetor.
I built this system for my 1915 using a garret T3 of an 80's 2.3l chrysler and a 40 dellorto.
Are you using a stock engine? For a 1600 turbo if you use a cam like engle 110 and some nice heads with slightly bigger valves and a good clean-up on the ports, I'd look for a turbo of an 1.8l -1.9l production car.
Good luck! Keep us posted!
Carsten
November 26, 2009, 08:47:14 am »
Quote from: sam P on November 25, 2009, 23:01:27 pm
Hi Carsten,
What i see on the pic , is somehow what i am looking for and try to do... Do you have it in your car ? Does it work ? Any more tech informations on your engine ?
I get a stock 1600 cc next week , which i will open and check and rebuild.. Maybe go 1641 do a little porting and balancing and so on.
I found some information which turbo will be good , maybe use a Garrett T3 or T25 or a Schwitzer S1 . Easy way would be to get a turbo header and intake for a Weber carb and build the rest around it. A complete or allmost complete kit would be ok , too. Lets wait and see. The whole should be a low budget thing , horesepower is not that important , more important is every day use should be somehow possible.
Ok , it would be much more easier to buy a complete kit , for example from lowbugget , incl. all the stuff i need , but it is not that oldschool and i like the look of a Weber carb turbo setup :-)
Greets , Carsten
1969 IRS bug
November 26, 2009, 11:30:55 am »
you're looking after something like this
Carsten
November 26, 2009, 11:35:19 am »
YES ! That is the way i will trie to do it ! have you got some more informations ?
Greets , Carsten
1969 IRS bug
jamiep_jamiep
November 26, 2009, 12:11:44 pm »
That Rayjay setup Martin has is about as period perfect as you can get, and the turbo's are as tough as old boots... I ran one earlier in the year and it was ancient, but did what it said on the tin
Then I got my T04 from JamieL which works great.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Carsten
November 26, 2009, 12:16:43 pm »
Quote from: kaferboy on November 26, 2009, 12:11:44 pm
Martin ?? Who is that ? I wait for an answer and pics of matt , but maybe mat is martin
Greets , Carsten
1969 IRS bug
November 26, 2009, 15:25:11 pm »
Quote from: Carsten on November 26, 2009, 12:16:43 pm
Greets , Carsten
no it's 65 goldturbo
aka muffler marts
Martin Greaves
10.88@128.58
November 26, 2009, 20:05:32 pm »
HI Carsten
Jamie(kaferboy) has got it wrong Matt(All Torque) is the one with the Rayjay setup not me.
As Jamie has said the Rayjay setup will be as period perfect as you can get and will work great.
JamieL
November 26, 2009, 20:15:52 pm »
A little .42/.48 A/R T3 will work on a 1600 with a little carb - for which there are loads of options...
40DCOE/DHLA drawthrough with 24mm vents - as on Panic Attack buggy
Or blowthrough whatever you fancy - stock Solex or Renault 5 turbo or....?
Or drawthru a 1.5" SU as Volksnut did in the states...
Or a small 2 barrel Holley like AJ Simms...
My first turbo engine used mechanical Bosch K-Jet with a Mitsubishi TE05-12B turbo in draw-thru config (similar to Russ Fellows original motor using some of his old parts in fact)
But thats kind of modern-old-school...
JamieL
November 26, 2009, 20:21:41 pm »
Carsten,
Check out
http://volksnut.com/
for some old school pics and info...
NB - there isn't meant to be a www at the front
Some especially good bits here:
http://volksnut.com/?page_id=5
Last Edit: November 26, 2009, 20:29:30 pm by JamieL
Carsten
November 26, 2009, 20:31:28 pm »
Quote from: JamieL on November 26, 2009, 20:15:52 pm
Or take a SU hif 44 Carb from a metro turbo engine blowthrough....
But my prob on build it myself is , that i do not know which turbos i can use , because of the seals , so if it can handle drawthrough ( carb before turbo )
1969 IRS bug
jamiep_jamiep
November 27, 2009, 08:55:23 am »
Sorry for the confusion Matt, Mart & Carsten - for some reason I thought Matt's post was by Martin Taylor.... it had been a long day
I was just reading an old issue of Volksworld from 1992 featuring Dave Perkins blue 66 - that thing ran a rayjay turbo into the nines in a floorpanned bug....
For the old school look Carsten really you'd have to go draw through - just my opinion.... I'm not saying its necessarily better though.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
jamiep_jamiep
November 27, 2009, 09:09:34 am »
Here's a couple of pictures of the Rayjay setup I used to run.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
volksnut
November 27, 2009, 14:12:53 pm »
JamieL, look up Brian F
BFye@canyonville.net
last I heard he still owned the Bernie Bergmann kit I had sold him for sale, it was from the 80's...here it was installed on my car
sam P
November 27, 2009, 18:18:43 pm »
Hey Carsten, if you want something affordable to drive around while you're building your big engine, i'd definately go with a complete kit. Building a system yourself may look cheap in the beginning, but it is a lot of work, takes time; trial and error, and it can easily get out of hand.
Quote
Did you try that Jamie? I had one of those on a stock 1600, it was just slightly faster, but it didn't really make any boost. It's good for my 1915 though.
Thanks for those shots of Insanity, Fabian! I was hoping you'd post that. Do you have any more info of that car?
Any engine shots/info on Bob McClure's Little Leroy perhaps?
November 27, 2009, 19:14:15 pm »
November 27, 2009, 19:15:30 pm »
November 27, 2009, 19:16:34 pm »
November 27, 2009, 19:17:38 pm »
Carsten
November 27, 2009, 19:51:10 pm »
HO !!!! Thank you very very much for all that help , pics and infos!!!!!!!!!!!!!!!!!!!!!!!!!!!
One more question , the Rajay turbo looks allmost the sam like a Schwitzer S1 turbo , i found som infos , that a S1 will be able to be used for such a syszem !? Anyone knowes something about that ?
Ok , a complete kit would be the best , i know , but the last one for sale was so long ago , that i did not know when it was... And it was not in europe.... ;-)
Plan B which i thought about , is getting me a header , maybe a Schwitzer S1 from a Deutz engine , and a 40 DCOE Weber carb. T pipe is not a problem....
Next plan , buy a cit from lowbugget...!?!?
Or wait for the next kit which is for sale.....
Greets , Carsten
1969 IRS bug
JamieL
November 27, 2009, 20:41:17 pm »
Quote from: sam P on November 27, 2009, 18:18:43 pm
Quote
Not personally, but I hear what you're saying - many others have been successful though and, from my research, the key to success is generating good exhaust gas flow/velocity using small valves, a small diameter header with NO leaks, low duration cam (stock or maybe Engle 100/110) and a small carb - also don't retard the ignition until you make boost...
You can also definitely get a carbon seal for a T3 for drawthru...
Plus, as you say, the same turbo will also work on bigger engines too - a friend over here had great success and reliability with a 2276 T3 40DCOE draw-thru motor. IMHO probably because the turbo was undersized and a limiting factor, but it worked a treat!
Carsten
November 28, 2009, 14:02:53 pm »
After som little more research , i think what coul help me is a book !
TURBOMANIA :-)
So, anyone out there here in europe or wherever , that has this book up for sale or as pdf ? Ok , can buy it new at cb , but shipping costs are too high...
What do you think ?
Greets , Carsten
1969 IRS bug
jyri eramaa
no cuts - no glory
November 28, 2009, 19:18:44 pm »
here´s my contribution.
a kawell turbo setup, made for a 300 hp 1600 cc engine.
now sitting on top of a 2332cc...
coming to my black KG
http://volkswanker.blogspot.com
Last Edit: November 28, 2009, 19:25:42 pm by jyri eramaa
November 28, 2009, 21:54:07 pm »
here's some old drag turbo engine , f you want more info let me know and i will post the report
fabs
