October 12, 2026, 05:35:46 am
Camshaft Registry
Topic: Camshaft Registry (Read 120744 times)
Re: Camshaft Registry
Reply #60 on:
May 29, 2017, 22:23:51 pm »
I wish I could come up with a cam card for the early Berg roller cams ... but I can do that on my own I suppose!
I have one catching dust on the shelf ... LOL
TxT
Last Edit: May 30, 2017, 00:15:41 am by TexasTom
Dominick Luppino
Reply #61 on:
May 30, 2017, 16:24:28 pm »
Buy one of these, you'll know more about what cam numbers then you would want to know...
https://www.indiamart.com/proddetail/cam-profile-machine-13164948148.html
Reply #62 on:
May 31, 2017, 02:27:45 am »
Not very hotrod-ish, sorry!
But if you have a mild nearly stock engine this is the best cam I've used. Really smooth, great economy, and broad torque band, stock or 1.4s rockers.
Schneider probably still have the cam number.
OK, back to hotrod stuff.......
Last Edit: October 13, 2017, 06:20:42 am by modnrod
Reply #63 on:
June 06, 2017, 23:56:13 pm »
Quote from: Dominick Luppino on May 30, 2017, 16:24:28 pm
Thanks but I'm good ...
I have a dial indicator and a good degree wheel.
Reply #64 on:
June 07, 2017, 18:01:06 pm »
Quote from: TexasTom on June 06, 2017, 23:56:13 pm
Yep and a scratch pad to do your math... it's good to keep it simple.
Dominick Luppino
Reply #65 on:
June 07, 2017, 18:26:26 pm »
It just saves time knowing exactly what you're installing in your Engine, I've had Cams that weren't even close to the cam tag.....but hey, what do I know...
Reply #66 on:
June 08, 2017, 14:42:29 pm »
Quote from: TexasTom on November 26, 2009, 18:39:09 pm
Engle W125
Still my all time favorite. I ran my first one retarded four degrees in the '63 (1835cc). Mated up to a close-ratio trans, it pulled hard in third and fourth...
Reply #67 on:
September 26, 2017, 21:46:02 pm »
Quote from: Dominick Luppino on June 07, 2017, 18:26:26 pm
That's why I have a degree wheel and a dial indicator!
I had a couple cams checked on one of those, but they were set up wrong and the data was useless.
I literally rechecked them in the case ...
Tools are only as good as the user!
bedjo78
Reply #68 on:
September 16, 2018, 07:52:42 am »
I am looking for FK97 cam card. pls share if you have it. thanks
Dougy Dee
Reply #69 on:
September 16, 2018, 22:19:37 pm »
Quote from: bedjo78 on September 16, 2018, 07:52:42 am
Advertised Duration: 328
Cam Lift: 0.443
.050 Duration: 287
IO: 37
IC: 70
EO: 73
EC: 34
Lobe Centers: 108
Overlap: 71
Info from old Cam Card
Drag race only; 1.4:1 rockers. Wide Base Lifters
bedjo78
Reply #70 on:
September 17, 2018, 05:20:52 am »
Many thankss
Reply #71 on:
March 07, 2019, 17:14:36 pm »
W130
