June 10, 2026, 03:13:19 am
mvptkfjb
Project 66-54
Topic: Project 66-54 (Read 16819 times)
Dereck
Project 66-54
November 27, 2009, 00:34:24 am »
New face, new project... Here's my 66 Bug, owned it for about 18 months and now I've got my backside into gear and started working on it.
I'll try and keep you all updated, but you can always follow my progress at
http://wackyracers.posterous.com
Last Edit: January 04, 2012, 23:18:23 pm by Dereck
Follow me on Twitter:
http://www.twitter.com/vondirk
Follow the progress of my Project '66:
http://wackyracers.posterous.com/
jamiep_jamiep
Re: Project 66
November 27, 2009, 10:39:56 am »
Can anyone else see the pics - I can't!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
jamiep_jamiep
Re: Project 66
November 27, 2009, 10:42:41 am »
Just had a look at the blog - what are your plans?
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Re: Project 66
November 27, 2009, 11:00:21 am »
Quote from: kaferboy on November 27, 2009, 10:39:56 am
NOPE!!!
Dereck
Re: Project 66
November 27, 2009, 13:22:21 pm »
Sorry Guys,
I've replaced the image links with some from my Flickr account, seems posterous doesn't like you linking to images...
Anyway plans at the moment are to sort out the couple of areas of rot, then build it up for racing. As I don't have any budget I'm going to stick with the 1600/twin 40 IDF set up and see how I go. Theory is, if I put the car on a diet, I might be able to squeeze out some extra 1/10ths...
jamiep_jamiep
Re: Project 66
November 27, 2009, 13:40:39 pm »
You here of some great times from some small engine setups Dereck...
Wherabouts in the UK are you?
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Dereck
Re: Project 66
November 27, 2009, 15:41:22 pm »
Quote from: kaferboy on November 27, 2009, 13:40:39 pm
Hi Kaferboy,
I'm in Bexleyheath, Kent.
I'm hoping I can get a respectable time out of the 1600, it pulls nicely on the street. It is slightly over jetted at the moment and is going to need an electric fuel pump to help with the starting issue I have. If I can keep the weight down I might be able to achieve reasonable times.
Black Sheep
less is more
Re: Project 66
November 27, 2009, 19:45:05 pm »
Welcome to the lounge Dereck .
What starting issue ? you should not have too many probs with 44idf's on a stock pump with a 1600 .
I still run a stock pump with 48 ida's on a 2165.
40's should be fine on a stock 1600 motor with the correct jetting .
13.03 @ 98mph
Re: Project 66
November 27, 2009, 21:37:17 pm »
Quote from: 49-rag on November 27, 2009, 19:45:05 pm
and you manged a sub 20sec quarter
Black Sheep
less is more
Re: Project 66
November 27, 2009, 21:50:44 pm »
Still managed a quarter
13.03 @ 98mph
beetletom
Re: Project 66
November 27, 2009, 22:01:34 pm »
thats seriously cool!
even the cookiecutters go with it!
is the steering wheel for sale?
is it a genuine thump thump one?
Last Edit: November 27, 2009, 22:03:36 pm by beetletom
Dereck
Re: Project 66
November 27, 2009, 23:33:33 pm »
Quote from: beetletom on November 27, 2009, 22:01:34 pm
Cheers for the kind words. I could be persuaded to part with the wheel & boss. I don't think it's a genuine Thump Thump wheel, but it could be. It's coming off this weekend, so I can take a proper look at it.
Dereck
Re: Project 66
December 30, 2009, 19:29:50 pm »
Managed to spend nearly a whole day in the garage today. I'll post up some pics in a while. In the mean time take a look through some of the previous work I've been doing here:
Re: Project 66
December 30, 2009, 20:47:51 pm »
Welcome to the lounge dude BUT the thread tittle "PROJECT 66" Has already been taken by ME
I know I haven't updated it in a while
FIDDE
Re: Project 66
December 30, 2009, 23:35:42 pm »
I like it,,,,,,,,,,,,
Last Edit: December 31, 2009, 00:01:53 am by FIDDE
Dereck
Re: Project 66
December 31, 2009, 17:13:15 pm »
Started the day taking off the front left wing...
and ended the day like this...
For the full details check out my blog:
Dereck
Re: Project 66
October 17, 2010, 18:58:18 pm »
Not posted an update for quite a while, to be honest I lost motivation again. Any I seem to have picked up a bit of incentive, which has nothing to do with me turning 40 next March and not having a cool ride...
I spent the other evening going over my Bug again. Trying to work out if the body is as bad as I thought...
The bottom of the left A-post will have to be replaced.
So that's three patches on the right heater channel. One with home made vents... One runs the full length of the door opening, which is spot welded to the top of the heater channel and the floorpan, why?
I managed to break the spot welds with only a screw driver. Looks like the bottom of the channel is rotten, I'll know more once I get the seats out and remove the offending plate.
Last Edit: October 21, 2010, 00:03:14 am by Dereck
Dereck
Re: Project 66 (where have all these 66's come from?)
October 17, 2010, 19:01:51 pm »
Decisions over the back end, it's been cut off already for easy access, but I don't like how it's been done. This shot shows how it was done. The box tubing is used to locate the back end which is held in place with a pinch bolt.
Ideally, I'd like just the rear valance removable. Should I weld it all back on the remove the valance?
Last Edit: October 21, 2010, 00:03:55 am by Dereck
Dereck
November 06, 2010, 19:07:26 pm »
Snuck out for half an hour and managed to free the door screws. Doors both off, let's hope the body follows soon?
Dereck
Re: Project 66 - Update time
January 04, 2012, 22:51:41 pm »
Over the summer a few things got in the way of me updating my build thread, but now it’s time for an update. As I previously mentioned I had located another body shell to replace the 66’s. After checking it out in person I decided to go for it. Well it’s not often a RHD 54 shell lands at you’re feet is it? OK I know the 66 would probably be an easier and quicker project, but I couldn’t turn down this opportunity.
The new shell does need a lot of work, it’s had some hefty patching over it’s life, but still retains it’s original heater channels - although heavily modified. Someone has also cut a darn great hole in the roof too, guess I’m going to have to fine a rag-top to fill it with? It’s all home safely tucked up beside the 66 ready for me to start work on.
Last Edit: January 04, 2012, 23:17:31 pm by Dereck
Dereck
Re: Project 66-54
January 11, 2012, 23:32:44 pm »
Last night I sold the 66 shell, guy turned you with a long wheelbase can and we squeezed it in. So that now leaves me with a rolling floorpan, ready to crack on.
Last Edit: February 01, 2012, 22:13:23 pm by Dereck
Dereck
Re: Project 66-54
January 31, 2012, 00:38:42 am »
Within a few hours I managed to go from this
to this
Now the fun can begin...
Last Edit: February 01, 2012, 22:12:58 pm by Dereck
Dereck
Re: Project 66-54
February 01, 2012, 22:15:34 pm »
A few more shots of the floor pan, it's certainly received its fair share of 'patches' over the years.
