June 10, 2026, 03:33:02 am
mvptkfjb
Rancho Pro-Street gearbox
Topic: Rancho Pro-Street gearbox (Read 119003 times)
Re: Rancho Pro-Street gearbox
Reply #60 on:
January 23, 2010, 10:17:33 am »
Quote from: JHU on January 22, 2010, 15:00:49 pm
Quote from: nicolas on January 20, 2010, 20:37:50 pm
it rained more then half a day on saturday at SCC this year.
And that's our only excuse for such a poor number...
henk
Reply #61 on:
January 24, 2010, 15:43:50 pm »
Quote from: henk on January 20, 2010, 13:13:21 pm
hallo,
so wich parts are used then from a stock gearbox?
if i buy a empty rancho core and build a stock gearbox over in it an add HD sidecovers and a super diff.
do i have then a good gearbox,or do i see this to simpel?
and is this a waste of money and should i better buy a complete rancho?
henk!!!
hallo,
nobody,that can give me an answer to this?
henk!!!
Reply #62 on:
January 24, 2010, 21:27:04 pm »
i cannot fully answer your question henk, but if you decide to do so there are other parts to take into account:
- the stronger 9 thooth 3.78 1st gear, obviously.
- differing strength between the 3.88, 4.12 and 4.37 r&p, something i didn't know. apparently 3.88 is strongest and 4.37 weakest.
- keyed or splined gears. later gears and early gears are not easily interchangeable unless you machine the later mainshaft. turned it down and insert a woodruff key.
- woodruff keys need to be hardened.
- 3rd and 4th gear should be welded to their synchros.
- then you would want a later shift fork as it's stronger.
- pref. heavy duty SAW axles.
- a gusseted case is stronger, too.
- and a latin american rhino case is strongest. rhino, that even sounds strong
i can't vouch for all of these bullets points to be 100% correct, but i've been thinking the same thing as you have. i think uncle keith wrote some good points in his performance handbook under fast road and all out street. take a look if you have that book.
DVK ~
Rasser
Reply #63 on:
January 25, 2010, 16:41:02 pm »
Quote from: 67-indeed/DVK on January 24, 2010, 21:27:04 pm
Add to that list:
Handpacked needlebearings, or use the earlier steelcaged bearings (they pins are wider in them).
Other than that, it is a VERY good list of things to remember when building a gearbox
1955 type1
1966 type2 13w deluxe
Reply #64 on:
January 25, 2010, 19:02:02 pm »
Rhino case isnt stronger,its just new,the material is often softer than old german cores,I would always try to use a good old case over a rhino,just my opinion though
And as for SAW axles,well I will bite my tongue on that subject
cheers richie,uk
Reply #65 on:
January 26, 2010, 04:33:55 am »
Quote from: richie,uk on January 25, 2010, 19:02:02 pm
I'll agree with that. The increased webbing on the top of a Rhino case does nothing to strengthen the gearbox in a rear engine configuration. The gearbox always splits at the bottom. A German case with a gusset welded on will live longer.
And SAW axles are junk.
kingsburgphil
Reply #66 on:
January 26, 2010, 05:46:10 am »
Bruce, can you enlighten me as to the pros and cons of SAW axles? I have a pair in my car, but have yet to have formed an opinion
of them.
If and when I do manage to break one, can you recommend a better axle? We are talking about swing axles...right?
Last Edit: January 26, 2010, 05:55:04 am by kingsburgphil
Reply #67 on:
January 26, 2010, 06:38:59 am »
My experience with them is limited but.... I think on a street car with radials they are not needed. If you do use them take a file or a grinder and totally smooth all the edges on the spade end down until they move freely in the end gears. This will keep them from getting chewed up on the ends.
Reply #68 on:
January 26, 2010, 07:36:01 am »
15-20 years ago SAW axles were indestructable.
Now, breakage is common.
SAW now equals China junk.
Reply #69 on:
January 26, 2010, 09:53:58 am »
thanks for the comments on my list, i'll take it into account
now that SAW axles are junk, are stock axles equally destructible or which axles are recommendable?
let's put things in perspective richie, most of us here don't have 9 second cars
DVK ~
Felix/DFL
Reply #70 on:
January 26, 2010, 12:42:54 pm »
Quote from: Rasser on January 25, 2010, 16:41:02 pm
Add to that list:
don`t forget the CrMo plate if you are using the old 4 bolt/plate type case
And you want to have the older raw teeth gears 3/4th and not the newer mouse teeth
One thing I am currious about:
Why remove some "pin`s" ( I have seen every second) on the synchros? Only for faster shifting or is there even an other reason?
The remaining "pin`s" are stressed that way way higher
Rasser
Reply #71 on:
January 26, 2010, 23:00:26 pm »
Quote from: Felix/DFL on January 26, 2010, 12:42:54 pm
Add to that list:
Yes I have seen that too, why?
1955 type1
mcmscott
Reply #72 on:
January 27, 2010, 04:03:23 am »
Volkswagen gearsets ran in "sets" of engaugement teeth(sorry my spelling is horible)when these sets wear out the gear will pop out of gear,so when rebuild time comes around you remove these sets and now they engauge in "new"sets. Some firsts are 2 sets of three and some are 3 sets of 3, most all3-4 sets are 3 of 3 then about 70-71 VW made them 5teeth in 3 sets( only in 113 style gears)These are very desirable for hand welded hubs. Most aftermarket gears (Weddle ect,) have all teeth engauging. If you look at the engaugement teeth on a stock gearset you will see the wear patterns. Hope this helps and hope I did'nt piss in anyones outmeal
Susy
PowderPuff VW Racing Rocks
Reply #73 on:
February 01, 2010, 04:48:55 am »
Quote from: Bruce on January 26, 2010, 07:36:01 am
Don't blame China blame SAW
MSH Racing
1970 Karmann Ghia
Type 1 - 2400cc 48 IDA's - 12 Second Street Car - Pump Gas
PowderPuff VW Racing Coordinator
2009 & 2010 Series Two PowderPuff Champion
kingsburgphil
Reply #74 on:
February 01, 2010, 06:20:35 am »
Quote from: Susy on February 01, 2010, 04:48:55 am
Amen....and well stated. You order shit.....You get shit!
Baring a QC issue or proprietary materials/processes the Chinese can manufacture anything as well as anyone else can. We should bear that
in mind the next time we fly on a Boeing airliner....major airframe components are made....Yes!! in China!
Two "Open" questions, if the fast guys say SAW axles are "junk" OK. If so, then in comparison to what?
And finally....Why do the "Worlds finest transmission" builders recommend and sell them if they are "junk"?
I'm not defending SAW products, i just don't want to shit an axle at the line if i can help it.
Sorry for the salty language
But the definition of profanity is "an empty mind trying to express itself"
Reply #75 on:
February 01, 2010, 09:09:35 am »
Quote from: kingsburgphil on February 01, 2010, 06:20:35 am
What do you propose they should sell instead? What are our options?
Gunter
Reply #76 on:
February 01, 2010, 09:23:32 am »
Quote from: JHU on February 01, 2010, 09:09:35 am
we have the Finnish production in stock ... but that is a different price range compared to SAW
plse email me for all info at
gh@csp-shop.de
Gunter
Reply #77 on:
February 01, 2010, 09:24:40 am »
hope this helps
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=detail&artnr=501%20201%20111AHD
HD Axles - Made in Finland
Product Description:
The high-quality finnish swing aceaxles. Made from the finnish MOCN315 metal with the years of professional experience, started 1960. The axles are developed and tested in co-operation with the finnish top VW-racedrivers since 1992.
Qty Item / Partnumber Price
HD Axles 61-66. short shaft. short splines
501 201 111AHD
available from stock
HD Axles 68-. long shafts. long splines
501 201 311HD
HD Axles 76 mm shortened. short splines
501 201 313HD
Last Edit: February 01, 2010, 09:27:25 am by Gunter
Reply #78 on:
February 01, 2010, 09:33:03 am »
I know Gunter, but those are in a separate league... and our ONLY other option?
Reply #79 on:
February 01, 2010, 09:34:54 am »
Probably old news. When they made the recommendation, SAW was the best. This begs the question: is SAW now owned by EMPI?
Gunter
Reply #80 on:
February 01, 2010, 09:43:36 am »
Quote from: JHU on February 01, 2010, 09:33:03 am
I know my friend ... but for reasons well stated in this topic we decided to offer to the public on a regular base
that is why we started to stock them
and off course to help our Finnish customer (also member of the Lounge) market his product
are you coming to VoWo show this year ?
Reply #81 on:
February 01, 2010, 09:51:37 am »
Yes this year I'm going! See you there?
Gunter
Reply #82 on:
February 01, 2010, 11:24:57 am »
Quote from: JHU on February 01, 2010, 09:51:37 am
for sure
Reply #83 on:
February 02, 2010, 11:27:56 am »
Quote from: 67-indeed/DVK on January 26, 2010, 09:53:58 am
Reply #84 on:
February 02, 2010, 11:32:19 am »
Yes,but i was talking about people breaking them with 12 and even 13second cars,even people breaking them on the street
On some big turbo cars they had to change them every 5 or 6 passes,this equates to proberly 70 or more pases for you but they will break and it can get really messy when they do
I had some custom 300m rifle drilled axles made for my car,expensive but they will keep it out of the wall
so worth every penney
cheers richie,uk
Reply #85 on:
February 09, 2010, 20:03:38 pm »
you just need the right CV's to mount them and they are fine.
btw great save when the axle broke... really impressive.
Reply #86 on:
March 07, 2011, 23:41:53 pm »
So, after reading the topic (more a pissing contest) over and over again we're back to zero. I would like to have a "bulletproof" swingaxle box for my 2165
street
car.
Harry
Last Edit: March 07, 2011, 23:49:00 pm by Harry/FDK
Reply #87 on:
March 08, 2011, 12:01:30 pm »
Have on custom made to your specs with a quaiffe diff
Reply #88 on:
March 08, 2011, 12:52:28 pm »
... and finnish axles.
DVK ~
ovaldriver56
Reply #89 on:
March 08, 2011, 21:36:37 pm »
Quote from: Bruce on November 28, 2009, 23:01:28 pm
Quote from: 181 on November 28, 2009, 21:44:28 pm
so I take it that ProStreet box use weak early 3.80 first gear?
If the gearbox is advertised as a "Pro-Street", it has the weak first gear. If it is a "Pro-Street Plus", it has the strong 9 tooth first gear.
That´s interesting. I just ordered a Rancho por-street ransmission at CSP
http://www.csp-shop.de/products/13618b
On their site, it´s advertised with a 3,78 1st gear!
Last Edit: March 08, 2011, 21:40:48 pm by ovaldriver56
