September 22, 2026, 03:12:27 am
| | |-+  Rancho Pro-Street gearbox
Pages: 1 2 3 [4] Print
Author Topic: Rancho Pro-Street gearbox  (Read 126187 times)
ovaldriver56
« Reply #90 on: March 09, 2011, 19:36:13 pm »
Does that mean, that is advertised with an 3,78 first gear, but it doesn´t has it installed?
« Reply #91 on: March 09, 2011, 21:28:22 pm »
Best to ask Gunter. But if it's advertised it should be in there..
ovaldriver56
« Reply #92 on: March 13, 2011, 11:41:48 am »
Maybee Gunter could give a statement?
« Reply #93 on: March 13, 2011, 16:04:47 pm »
maybe ask him personally, i'm not sure he (regularly) checks each and every topic on here.
181
« Reply #94 on: May 16, 2011, 15:24:01 pm »
So..decision time. Going to pick up my new rancho gearbox on Wednesday.
What would you choose? 4,12:1 or 3.875:1 gering? I´m set on 0,89 4th and I don´t have cash to design and set up fully individual transmission.
Type 181 weight is 900kg with fluids, 1 ton with me :-)
Engine is 2276cc, FK8 cam, 1.4 rockers, steve tims stage 2 heads (42x39), 48 DRLAs with 40 vents on lo...ong intakes, 1 5/8 exhaust, around 160RWHP I believe?
sporting 205/65R15 radials on the back.
BRAINSTORM NOW!
Thank you all!
« Reply #95 on: May 16, 2011, 17:45:06 pm »
I've made a big mistake: 4.12 R/P with 0.89 4th gear. Waaaay to long.
181
« Reply #96 on: May 24, 2011, 09:24:16 am »
I do some freeway driving so I can´t have close ratio transmission Embarrassed
Rocket Ron
It's old school for a reason
« Reply #97 on: May 24, 2011, 22:22:05 pm »
if its any help
my bug is full weight with extra dyno mat etc ie heavy
ran a 13.73 with treads  a 1.97 60 ft and no lightening with a very similar engine to yours k8 1.4 42 x 39 and 8.1 compression and 48idas with 40 vents not DRLAs ie tame
rear tires are 205 75 15
box is a pro street with super beetle first 3.88 ring and pinion and a .89 4th
mph through the traps was 96.42 mph in 4th
would do 80 ish in 4th just under 4000 rpm if i remember rightly  Wink
Regards Ron
13.12 @ 101.84
Grooving out on life
181
« Reply #98 on: June 10, 2013, 11:45:45 am »
Hi again after 3 years:-)
Finally I purchased and ran Pro Street transmission in stock trim with 4.12 RP and ran it for two seasons. It runs very good in town and countryside driving I´m under impression it kills my 1/4 mile times a lot.
What ratios would you suggest for my 2276 with 86C cam, 11:1 CR , 48DRLAs, 1 3/4 CPS python. I run a full metal VW Thing on swingaxles, good rubber mounts, CSP trapese system, no problem with wheel hop whatsoever. Berg shifter, new shifter bar bushing, Dieken Copper disc and Stage 1 KEP plate. The car still weight around 2000 lbs with me. I´m ready to run ERCOs with 215/65 m+H DOTs on the rear.
I´m ready to run close ratios if it still allows me to get to races at reasonable speed (no autobahns). Please design me a gerabox of your opinion.
Thanks!
dragvw2180
« Reply #99 on: June 10, 2013, 16:00:37 pm »
Since your gear box has held up so well why not go back to the same builder and ask their opinion ? Sam , the owner of " Rancho " and I have been friends and a customer since the early 80's and his advice has always been excellent plus he is absolutely honest .  There are alot of competent and honest builders out there but how many have built the quantity that Sam and his " companies " have , with that comes experiance of what combinations work . I will give you an example, I am building a new "Street Car " that will have 366 rwhp . I will be using my old race transmission and no it will not be perfect for the street but it is a compromise just like your car , something I can drive to town and yet race . Will I want to drive it 70 mph for an extended period of time, hahhahaahh NO , but I will drive it to local shows with my wife and to get the occaisional meal . Would this be the gearing Sam would advise me to use  , No,  he would probably laugh at me for even thinking of it. I will be using 26 ' tires and a 3.88 r/p with a 1.14 4th  . I look forward to all the responses you get with your post. Mike McCarthy
P.S. this is an old vid of the engine and transmission I will be using in my street car, the red one,
<a href="http://www.youtube.com/v/FJZrEFElU24" target="_blank">http://www.youtube.com/v/FJZrEFElU24</a>
pupjoint
« Reply #100 on: June 11, 2013, 04:41:39 am »
Thanks!
what ratio is your current pro street gearbox with 4.12RP? stock? any other mods? super diff? LSD?
« Last Edit: June 11, 2013, 04:51:15 am by pupjoint » Logged
pupjoint
« Reply #101 on: June 11, 2013, 05:34:18 am »
check out some of the pics posted by Paul Guard
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1023716
http://www.thesamba.com/vw/forum/album_page.php?pic_id=985963
« Reply #102 on: June 11, 2013, 08:33:56 am »
I have a 4.12 gearbox with 3.78, 2.06, 1.44 and 1.04 gears. Very happy with it and works perfect with my webcam 86c in my beetle. (2176cc 188 hp).
« Reply #103 on: June 11, 2013, 10:14:29 am »
Thanks!
hi pupjoint, yes, stock trim 4.12 RP,
1st Gear: 3,78
2nd Gear: 2,06
3rd Gear: 1,26
4th Gear: 0,89
super diff with 4 spider gears.
Thank you!
