September 01, 2026, 23:42:44 pm
Latest Member: Lotus67
| | |-+  getting the power down
Author Topic: getting the power down  (Read 6858 times)
dannyboy
« on: December 01, 2009, 20:07:26 pm »
hi all im getting my box sorted at the mo and ill be running slicks but at the mo the rear end is stock whats the best way to set up the rear end to get the power down a bit better traction bar? types of shocks ? snubbers (wotever they are lol) and someone else said i need limiting straps, again ??
cheers in advance Grin
8.77@156.8mph
O/FF 60
ESH
« Reply #1 on: December 02, 2009, 13:01:57 pm »
All the standard upgrades help to one extent or other, how much is possibly open for a little debate and I’m no expert but on a stockish set up the way you drive it is probably the single most important factor. You’re going to be working around a less than ideal set up for a combination with reasonable horsepower and slicks so you’re biggest advantage will come from seat time on the track. At the end of the day the more weight you take out and the more rigid the car the better. How far you can go with that depends on how many race type modifications you feel you can live with.
A good example of a regularly driven street car that is very efficient off the line at the track is Andy Marriott's as the slow motion clip shows. Basically it's a daily driver and runs 12 zero on a sub 2000cc motor, if you can talk to people who are getting the job done you should get some useful pointers based on experiences but if you’re going to be spending a lot of time on the strip then I’d balance the car more towards the strip and possibly consider a cage.
<a href="http://www.youtube.com/v/6qpD4X19IDs" target="_blank">http://www.youtube.com/v/6qpD4X19IDs</a>
« Reply #2 on: December 02, 2009, 13:23:17 pm »
As Mat says, a cage is a very good idea. I've been called a safety nazi by some who run very quick times with no safety equipment at all, but it's better to have confidence in your equipment rather than arrogance about your abilities. The two big bonuses about a cage other than safety - first you've got somewhere to mount the seat and harnesses, and secondly it's easy to make up some bracing for the frame horns, torsion bars and shock towers.
lowfastbus
WUNDERWAFFE
« Reply #3 on: December 02, 2009, 19:31:54 pm »
Look at the front wheels after the 2nd wheelie (around 1:30 in the movie).
Those look dangerous!! Shocked
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
andy M.
« Reply #4 on: December 02, 2009, 19:38:37 pm »
only if you've got no balls!
L.B.C.R.
dannyboy
« Reply #5 on: December 02, 2009, 19:44:10 pm »
ive got a cage that im going to fit  its a saftey devices 6 point as the saftey thing seems fairly important to me  Shocked
ahh mr marriot i may pick you brains on saturday about your setup Wink
8.77@156.8mph
O/FF 60
andy M.
« Reply #6 on: December 02, 2009, 19:45:33 pm »
Being serious for a second, which is a rare occurence for me, on the second run the car pulled to the right during the wheelie and me, being a bit of a spaz, started steering to the left whilst the front wheels were still in the air, resulting in the wheel wobble on returning to earth, and no I don't run with a steering damper, they are for poofters Grin
Andy
L.B.C.R.
andy M.
« Reply #7 on: December 02, 2009, 19:51:22 pm »
Always pleased to pass on gems of wisdom, but I can't hang around too long, I've got a 80's disco to go to Saturday night!
Don't get a Safety Devices cage, they aren't MSA legal and weigh a ton,
Andy
L.B.C.R.
dannyboy
« Reply #8 on: December 02, 2009, 20:01:54 pm »
i picked it up cheap so itll do for next season, im not gonna be racing properly only rwyb well for next year anyway  Smiley and once ive got the hang of it and am in the tens  Cheesy
maybee ill take it a bit more srious  Grin
8.77@156.8mph
O/FF 60
Stefan Rossi
« Reply #9 on: December 29, 2009, 02:38:23 am »
Iv got a safety devices one for mine but its only for next season. I have a harness bar welded in and plan to tie it in with the rear sock towers and frame horns aswell.
Im hoping that and a good gearbox, race axles, mid mount, traction bar, good pair of shocks and limit straps will do me ok for around about 13s or 12s in a street car wont it? Correct me if im wrong tho please!
Danny im goin to have a word with cogbox earlyish next year about gettin my car sorted for a good strong box!
Stef
Aircooled Engineering. Birmingham, England
www.ace-vw.com
Check us out on FB, www.facebook.com/aircooledengineering
www.dtavw.com
'67 vert
'67 Chevelle PT106mm turbo
'66 Lincoln
