September 24, 2026, 00:45:04 am
| | |-+  Mounting tire question
Author Topic: Mounting tire question  (Read 7313 times)
« on: December 07, 2009, 01:20:16 am »
I'm mounting tires on my two peice 5 spokes, With tubes, Question is cant get a last part of tire to fill out to wheel lip, Or last little bit will not pop out about 3/16 to 1/4 inch about 3-4 inch around wheel only on the front of wheel the rear is perfect. Tube is at max air preasure. I wonder if a tire shop might put some type of tube on outer premeter of tire then inflat tube in tire. I hope that makes a little sense
deano
« Reply #1 on: December 07, 2009, 02:01:00 am »
I think the girls up the street may have some suggestions for which lube to use....
Anglia Obsolete Guru
'67 Heaven
« Reply #2 on: December 07, 2009, 02:07:05 am »
Every tire shop uses rubber lube to mount tires. You can buy it at NAPA.....
« Reply #3 on: December 07, 2009, 02:41:52 am »
I did mount them dry, I thought was to keep moisture out of inner rim area , so you think lubeing tire edge better might get it to slide or slip into place. Just a little scary filling something with alot of air preasure trying to get it to finish moveing where it needs to be! dont want to blow the side of a bolted together wheel. dont need any fricken flying peices of wheel trying to kill me ! Ya call me a pussy
axam48ida
« Reply #4 on: December 07, 2009, 02:46:04 am »
The lube most shops and goodyear uses is a paste type lube to eliminate any moisture
go to any tire shop and should have some
Kaferdog
« Reply #5 on: December 07, 2009, 06:58:21 am »
Try Dish soap around the rim of tire ...?
John Rayburn
« Reply #6 on: December 07, 2009, 07:13:45 am »
I always used dish soap.
I also park at Nick's.
« Reply #7 on: December 07, 2009, 15:13:56 pm »
dish soap or spray a little wd40 around the edge
« Reply #8 on: December 07, 2009, 15:19:13 pm »
Dish soap, Danny. Problem solved. You don't want silicone (WD-40) on your tires, unless you hate them.
Speed-Randy
« Reply #9 on: December 07, 2009, 17:29:34 pm »
are we talking tires or the girls next door? Cheesy Cheesy Cheesy
« Reply #10 on: December 07, 2009, 18:11:25 pm »
There is almost two feet of snow between them and I. Thinking about some snow tires on the repo BRMs , What do ya think?
Dave Rosique
nobodyouno
« Reply #11 on: December 07, 2009, 18:17:57 pm »
This should look good on a BRM:
Dave Rosique
nobodyouno
« Reply #12 on: December 07, 2009, 18:21:49 pm »
Hey Danny,
I used to use a little gas when mounting my EMPI's... yeah, I know, not safe, blah blah, but it worked.
~DR.
benssp
www.callookvw.com
« Reply #13 on: December 08, 2009, 21:49:55 pm »
How about the 'Redneck Route' Grin
<embed src=" <a href="http://www.youtube.com/v/vLtBojvDEyc" target="_blank">http://www.youtube.com/v/vLtBojvDEyc</a>"
www.vwheritage.com  My Job
YMCA
Dave Rosique
nobodyouno
« Reply #14 on: December 09, 2009, 04:46:48 am »
Well... I wouldn't want anybody to get the wrong idea about me ~but~ I've used the "Redneck Route" many times... it works especially well when mounting ATV tires Grin
"If your house is mobile, but your cars ain't...
        ...YOU MIGHT JUST BE A REDNECK"
~DR. Wink
« Reply #15 on: December 09, 2009, 07:07:37 am »
HAHA!! You crack me up, Dave. Rock on, brother.
