August 14, 2026, 05:16:31 am
| | |-+  90.5 P&Cs in 94 cut case
Author Topic: 90.5 P&Cs in 94 cut case  (Read 5736 times)
« on: December 08, 2009, 20:02:45 pm »
Is there a way to put 90.5s in a case cut for 94s? Anyone have exp with the 92mm thick wall P&Cs that will fit a 94 cut case? Kicking around options for the Manx motor on a dreary Tuesday at work.
« Reply #1 on: December 08, 2009, 21:34:53 pm »
Perhaps the cylinder bases can be sleeved up to 94mm specs?  I am no expert, however.
« Reply #2 on: December 08, 2009, 21:48:50 pm »
I just got a quote on the thick wall 92s which will fit my case. The price is pretty reasonable, I may just go with those.
« Reply #3 on: December 08, 2009, 22:09:52 pm »
I decided to go with the thick wall 92s. Ordered a set form DRD. I thought $234 out the door with the proper hone was a good deal compared to the price of Cimas. So it looks like I will end up with an 1835 instead of the 1914, a true '70s size motor for the Buggy. Next up, carbs & heads.
« Reply #4 on: December 08, 2009, 22:16:49 pm »
Good deal.  I will probabbly get a set of them for something, someday.  I like the idea because the 92s have sort of become overlooked.  Plus now you can go post on theSamba.com that you are running 92s and everyone can try to beat you up...
« Reply #5 on: December 08, 2009, 22:20:18 pm »
I am hoping that they will run a bit cooler than the 94s.
« Reply #6 on: December 08, 2009, 22:42:00 pm »
my 94mm motor in my car right now is the "coolest" running engine ever in my car. Oh wait, I've only used 87's and 94's... never mind  Roll Eyes
« Reply #7 on: December 08, 2009, 22:50:17 pm »
Hey Louis I Got a Set Of 42 Dcnf's Berg Specials Wth Berg Manifolds ported for Tims Stage II's and Berg Linkage
« Reply #8 on: December 08, 2009, 22:51:43 pm »
So what Brand are they? A&A??
« Reply #9 on: December 09, 2009, 01:08:41 am »
Humm, I just bought a CSP linkage for a set of IDFs. Wonder if they will work on DCNFs. How much are the manifolds ported? I was planning to have Jeff D. do my heads and I would have to see if he could work with the manifolds or not. Shoot me a pm with the price.
Yes they are AAs but I spoke with Daren at DRD a good bit before ordering them and he says he has had good exp with them. And I don't plan to run above 8 comp with them anyway. That way I can run tractor gas in them if I have too.  Grin
