September 22, 2026, 07:09:27 am
| | |-+  My '63 Rat Notch
Author Topic: My '63 Rat Notch  (Read 12744 times)
notched
« on: December 17, 2009, 02:15:54 am »
I've been on this site for a bit. I know a few blokes on here. Or, Yanks, as the case may be. I live in Oregon, about 28 miles from the California border.
I have a lot of projects in the kettle, including: A '66 Variant Pigalle, a '66 Fastback (my son’s car, one owner, California car that originally had dealer installed air conditioning), a ‘68 Squareback (my first VW), a ‘67 Karmann Ghia Cabriolet (serious project), a ‘69 Fastback (automatic!), a '69 Squareback, a ‘70 Baja (son’s other car), a ‘70 Karmann Ghia (parts car), a ‘87 Cabriolet, a ‘88 Cabriolet (wife’s car) — whew! That’s a lot of typing.
But I'll post probably the most interesting VW that I have, is a ‘63 Notchback with a 2332 CB fuel injected motor. It’s always in a state of perpetual progress. I'm running DRD Stage 5 heads, MSD ignition and a Kymco 1 5/8" Type 3 merged exhaust.
Here is a concept for the Notch Rat: Stock wheels, no caps, fat tires in the back, skinny up front. Keepin' the paint all faded for now. I think I'll clear coat it with some satin.
Dan Evison is the engine builder - just so you know who Dan is...
Bolting the case together with the bearings (test fit):
Case bolted together with bearings:
Checking bearing specs:
Rods:
Crank detail:
Pics of me cleaning out the motor case, and deburring the edges:
Detail shot:
Made some progress on the motor! After tons of problems with two sets of rod bearings, Keller Machine finally found some bearings that worked! I ended up getting some Chevy 2.8l bearings that fit the bill. Last weekend spent a little time at Dan's shop and he started assembly. Had a little scare with one of the rod bearings, but Dan did a little filing, and everything is A-OK!! I am stoked!!!
One main bearing in place!
1st rod in place!
2nd and 3rd rods in place!
All four getting torqued down.
Final torque. Man they were all nice and smooth. I gotta give props to Dan, he really takes his time to make sure it's all right. All four rods felt nice and smooth. Looking forward for more progress!!
Some pics of the shortblock progress:
Case tapped for Type 3 full-flow
Checking the distributor drive shaft for clearance
Clearanced side of case for distributor drive shaft
Drive shaft in place
Installing small crank bearing
Small crank bearing on
Checking large crank bearing in case
Had a lot of problems with the key for the fan. You can see how this crank was machined too far down into the shoulder. The key kept moving to far down:
Here you can see the key pushing down too far:
After some creative clearancing on the key, it fit and the oil washer fit (what the hell is that thing called?)
Installing cam gear (ooooooo, I love the sound of straight cut gears!):
Installing cam bearings:
Checking cam play against thrust surface:
Cam back out, installing lifters:
Crank installed:
Crank and cam installed:
Now you can really see those straight cut gears! Cool
Closing the case (it will have to get opened up on more time after the cam is dialed in)
Case closed:
Check out the recessed washers:
Case fully bolted down, nuts torqued to 25lbs (remember this is not final):
Dropping in temp pistons and barrels:
Don't worry, we're just using these pistons temporarily to dial in the cam
The correct pistons are ordered for the 84mm crank
Dialing in the cam
Deck height tool used to find TDC:
If you look at No. 1 intake, Dan had a lifter with a rod welded to it
I think this is No. 1 intake...
It's tough to tell, but Dan is rotating the crank and watching the guage here:
Guage at TDC:
This is a nice closeup of the dial indicator guage and the lifter tool:
I guess this is the reader's digest big print version (degree wheel):
One bolt in cam gear getting tightend down after cam is dialed in:
So, that's where we're at. Short block pretty much done. Just need to pull the case apart and take out the lifter tool, drop in the rest of the lifters and tighten down the cam. Dan also wanted to make sure the cam bolts have enough clearance from the case.
Dan had to order some parts for the long block. He said we could hit it again next weekend. I'll have to bring more peanut-butter shakes...
Engine update. New build sessions.
This is where we left off. Short block was almost done. It sat in hibernation for a bit.
Balanced flywheel (balanced with whole rotating assembly, crank, rods and pressure plate)
Final assembly of short block. I didn't have all of the lifters in before. Cam plug wasn't in either. And, had to torque down the cam bolts.
Final torque of cam bolts
Cam in. Final assembly of the short block. I wish I would have taken more pics here. The other half of the case received the rest of the lifters. My engine builder had some cool springs to keep the lifters in place. I really wish I had a pic of that. O-rings added to the 6 case studs. Special German sealant added between the case halves. Cam plug in. One thing to note is that Dan likes to start tightening the two cam studs first on the case.
Test fit of full flow fittings
I'm using 94mm Mahle "B" pistons for the 5.5" rods
Adding cylinder studs (I don't know how I ended up with so many of these pics...) Engine builder had a cool tool that fit over the studs, and would allow for tightening without utilizing the threaded areas
My engine builder likes to set end play while the pistons and barrels are still off. Can't get an accurate measurement with them on.
The pistons were weighed and came out dead even out of the box!
Had to check the deck height. This motor is set up with a zero deck.
Pic of the shims used for the cylinders
Once the correct number and size of cylinder (barrel) shims were established, we started final assembly pistons and barrels
Some shots of my DRD Racing Heads – These are DRD Stage 5 heads. 40x35, ported and polished, matching intakes, bench flowed. Some of the pics have two valves out to see inside
Close up of the intake
CCing the heads (this may be out of order, I can't remember if we did this earlier)
Final assembly of the the heads
.060 copper head shims were used.
This copper shim was inserted into the head. I don't have a good pic of the copper shim in the head unfortunately...
One side
Other side
Voila! Almost a longblock! Just need to set up the valve train geometry.
Leak down test was between 12 and 18% for all cylinders!
Some Pics:
Push rods cut. Rockers installed. (I need to post a few more pics that I have here)
Here you can see the Kymco 1 5/8" exhaust not quite fitting on the 1/2 side. Just a little short.
Cutting at no. 1 port. Or is it no. 2?
Test fitting exhaust.
Welded back together.
Copper exhaust gaskets.
Finished exhaust.
Throttle body with exhaust.
Test fitting oil pump.
Pulling back out to see where cam bolts interfere.
Clearanced oil pump.
Pump drive gear welded.
New oil cooler stud.
Oil cooler and pressure fitting.
Oil cooler installed.
Cylinder tin over oil cooler.
Cylinder tin test fit on 1/2 side.
Intake manifold gasket. I had to match these to the ports. DRD marked them for me.
Intake manifold test fit.
Cylinder tin test fit on 1/2 side with deflector plate.
Test fitting the distributor.
Final installation of oil pump and test fitting of full-flow fittings.
Rear engine carrier test fit.
Installing muffler. I need to take this back off, but it kept Harrisen busy...
Setting up the throttle body linkage. Had to clear the distributor.
Inspecting the fuel injection wiring. This required taking off two miles of electrical tape...
Starting to hook all of the connectors on.
Gettin' closer!!
EFI + MSD wiring.
I need to tap the head for the head temp sensor.
EFI wiring.
Control box and switched wire.
Oil filter mount using Parker -8AN fittings.
Another pic of the oil filter mount.
Fan.
Pulley shroud on.
In this pic you can see the flange that I've removed from the sheet metal.
Alternator on with pulley and belt.
Here you can see the alternator and MSD distributor touching. I need to fix this so that the distributor can rotate.
Gettin' close!
Sooooo close!
3/8" fuel line running to the fuel rails on the throttle bodies. The coil is mounted, but I haven't added the connectors to the end of the wires yet. You can also see that I need to tap the head for the temp sender for the EFI.
This is a pretty good shot of the fuel line. I had to make a few bends to go around the distributor and center pivot for the throttle body linkage. I'm going to add the fuel regulator on the 1/2 side. I've taken off the alternator, until I can fix the clearance issue with the distributor.
Nice close up of the fuel line. The line is really close to the throttle body. I'm going to fix this with some fittings.
This is were I landed this weekend.
And a shot of my work area.
I'm in the final stretch of installing my 2332. Some recent pics...
"T" fitting on tank
Factory EFI fuel lines at end of pan tunnel
Fuel pump mounted — This is the first time I mounted this, I ended up moving it down into the front beam so that it's lower than the fuel tank
Shot of the new brake fluid reservoirs that my friend Ethan gave me (and installed!) a while ago
Harrisen, my son, removing the rear wheel to get access to the back fuel lines where they exit the pan
2332 EFI beast in the engine bay
Still working on lots of little details at this point. But the motor starts and runs in the car!
A few older pics of the flywheel, pressure plate and clutch getting installed
Measuring end play with a dial gauge
Aligning clutch with trans main shaft (works great!)
Pressure plate installed
Detail of pressure plate and flywheel balance marks (two zeros together by bolt)
Some more work on the Rat Notch...
This is how low the muffler was before — really low!
Muffler welded back on — this pic doesn't really show how much higher it is
Muffler with new bumper and hitch!
Cleaning bumpers
Front bumper mounted
I guess the tabs on the engine lids on the older Type 3s were smaller — we had to improvise and grind the tabs smaller from the donor '69 Type 3 engine lid
Harrisen, my son, working on the wiring for the alternator
Detail of the DDB alternator wired in — notice that it just barely fits with the MSD distributor
And all the dipstick parts getting cleaned in the dishwasher — shhhhhhh don't tell my wife Cindy!!
I have a #&%$ oil leak. I'm pretty sure the oil is leaking from the oil cooler... Someday Brian Fye will actually come down and fix this for me...  Grin
« Last Edit: December 17, 2009, 04:04:52 am by notched » Logged
notched
« Reply #1 on: December 17, 2009, 04:14:53 am »
Forgot to post one of the most important pics. The racing stickers!!
« Reply #2 on: December 17, 2009, 06:15:12 am »
You gotta watch that Fye -- your never know when he'll suddenly show up
Great pics and build Phill
Probably wore out that camera LOL
Hotrodvw
« Reply #3 on: December 17, 2009, 07:19:41 am »
WOW !  Nice write up Fill!  Now I gotta get mine done before you!   Cheesy
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
notched
« Reply #4 on: December 17, 2009, 08:05:04 am »
Yes you do! Plus, with that hair dryer, you should have about the same HP as me...  Shocked
Grin
Hotrodvw
« Reply #5 on: December 17, 2009, 16:09:25 pm »
And you have efi and 300cc more??  Oh yeah, you have more weight.  I dunno, the 1/4mi will tell!
Hose & Fittings
'67 Sunroof
notched
« Reply #6 on: December 17, 2009, 19:31:57 pm »
Are you callin' me portly?  Smiley
Hotrodvw
« Reply #7 on: December 17, 2009, 19:47:17 pm »
The car man!  The car!
Hose & Fittings
'67 Sunroof
notched
« Reply #8 on: December 04, 2010, 11:51:58 am »
Some updates...
Pulled motor. On stand. Pulling off 3/4 cylinder tin to get to the oil cooler and seals.
My old cooler seals were cracked and I probably over tightened the bolts.
I replaced them with new seals. And torqued the bolts down to 6-8lbs.
Everything back together.
While the motor was out. Harrisen and I fabricated a pseudo Kafer brace and a mid mount. I was really worried about flex in the frame horns. I'm not currently running the rear "mount" because the part on the body was really mangled by the PO. Eventually I will replace this and have another part reduce engine/trans flex.
Mid mount (I'm only using 2 studs for now, I will use 4 eventually when I update this.
Harrisen welding the mid mount in. Note: Harrisen is a Lefty!
Mid mount bracket fully welded in.
Finished welding in the brackets for my cooler above the trans
For my frame horn bracing, I used 1.000" tubing with a .120" sidewall. Very sturdy stuff. I've used it to make mini-sandrail frames and secondary framing on full-size sandrails.
Cutting to fit.
Fitting.
Cross brace tacked.
Welded in. Notice new (to me) shocks!
Both mid mount and two side braces welded.
Awaiting motor.
Ready to install.
Clearancing for coil. I will eventually move my coil to the right side.
Back in!
I hooked up all of the EFI and ignition electrical and fuel lines. No start.
Derek, my friend, came by and helped trouble shoot. Had some issues with my MSD loom. Had one connector that pulled apart, fixed that. Had the tach connector pull out. Fixed that connector. This is critical, because the EFI uses the signal. I think at this point, my friends Bryan, Rich and Robbie came by.
Also, had an issue with my MSD distributor. It wasn't seated properly. Fixed that. Had an issue with my ground strap to the body, pulled it, and cleaned the paint, er, rust off, and that was fixed.
Then she fired up! Set the timing. Timing was off before. At about 7 degrees at idle now. Not sure what total advance is. I had the wrong type of light for that.
I still, like before, have a flat spot at about 2200-2500 RPM. I need to call CB, and see if they have any ideas.
Next up is front shocks, fix my passenger door hinge, seat belts, ignition switch, lights.
Oh, almost forgot, new rear tires!
This is where I ended up while working on my passenger door just before surgery.
Still drilling out the lower hinge bolts.
Original door.
Broken bottom hinge on original door.
Hinge in donor door retapped.
Wobbled out holes welded up ready to get tapped.
Top hinge holes on door frame.
Took the Notch out for a little test drive after — Still have the stumble during the video, but it actually went away after driving around!!
<a href="http://www.youtube.com/v/j5AQVPiQJSk" target="_blank">http://www.youtube.com/v/j5AQVPiQJSk</a>
« Reply #9 on: December 04, 2010, 14:25:07 pm »
Very usefull and detailled engine built  Wink
« Reply #10 on: December 04, 2010, 15:32:40 pm »
as nico said   Wink
