November 04, 2026, 10:10:09 am
| | |-+  Electrical question?
Author Topic: Electrical question?  (Read 4388 times)
Brew 66
« on: December 19, 2009, 17:06:19 pm »
In a '68 - '70 type I should fuse #9 be hot when the igition switch if off?
I have a VDO volt meter hooked to that fuse and when the battery is hooked up the meter is reading 12volts. Shouldn't it read nothing until the key is on?
I disconected the stereo and all other "extra" electronics and it is still happening.
This is a 12volt generator car. I changed out the voltage regulator and no change.
HELP?
« Reply #1 on: December 19, 2009, 17:30:34 pm »
I think that should a hot terminal (fuse).  It looks like 9 and 10 should be hot.  Check out these links:
http://www.thesamba.com/vw/archives/info/wiring/bug_6869.jpg
http://www.thesamba.com/vw/archives/info/wiring/69bug_fuses.jpg
DKK Robert
« Reply #2 on: December 19, 2009, 17:34:35 pm »
I used this site to get the wiring diagram for my car, hope it helps you.
http://www.vintagebus.com/wiring/index.html
« Reply #3 on: December 19, 2009, 17:58:11 pm »
Of course I could be wrong if I was looking at the fuse box upside down.  Not sure...
Brew 66
« Reply #4 on: December 19, 2009, 18:19:39 pm »
How cool, I ask a question around the world and get an answer from just a couple miles away.
Thanks Don!
« Reply #5 on: December 19, 2009, 18:42:20 pm »
I believe from 5-on, they are always hot. The low beam lights and such you can always turn on without the key. So to answer your question 9-10 are unswitched, (always on). Hope this helps. I have a 69', went through the same thing. Those diagrams DO help.
Ted
