November 04, 2026, 07:20:27 am
| | |-+  2110 engine questions
Pages: 1 [2] Print
Author Topic: 2110 engine questions  (Read 24292 times)
« Reply #30 on: April 26, 2012, 05:44:05 am »
hallo,
still busy collecting parts for my 2110.
i'm looking for a case at the moment,but don(t know to much about them.
i can buy these one,it's a new brazil AS41 is it any good for a 2110 build?
henk!!!
Why didn't you use this case ? Looks very nice , one of the older ones that have no issues.
I would check the case too - never saw a lifter like that - also check lifter to lobe clearance at full lift
« Last Edit: April 26, 2012, 05:47:02 am by Udo » Logged
henk
« Reply #31 on: April 26, 2012, 09:49:29 am »
i bought a autolinea case then bored at 90,5,cleared,and ready for full flow for the same price as that standard case.
we sure gonna check everything again.
henk!!!
henk
« Reply #32 on: April 28, 2012, 19:30:40 pm »
my friend measurd everything today and this is what he came up with.
do you guys think that the coil bind is OK or should i get more?
if so how can i get more if needed,we shaved 2mm of the valve guides all ready and we installed the vw650 springs from CB performance.
Full lift @the valve 14,5mm(0.570)...... scat 1,48 rockers
Retainer to guide clearance @full lift 1.5mm(0.059)
lifter to bore clearance @ full lift 2mm(0.078)
coilbind @full lift 1.9mm(0.074)
henk!!!
« Reply #33 on: April 28, 2012, 19:45:46 pm »
henk!!!
I would change the rockers to cb or bugpack. You can not be shure all have the same lift,different ratios
« Reply #34 on: April 28, 2012, 20:59:57 pm »
henk!!!
When you measure full lift are you doing it with the vw650 springs in place? or a checking soft spring? and is that last measurement
the clearance you have at full lift?
I totally disagree with Udo on swapping the rockers,the only ones I have ever seen with a big variation from rocker to rocker were CB,but you should check all 8 valves/springs for coilbind to be 100% sure
cheers richie
henk
« Reply #35 on: April 29, 2012, 19:54:55 pm »
hallo Richie,
yes that was with both the springs in place.
and indeed that is the clearence at full lift.
henk!!!
Pages: 1 [2] Print
