October 06, 2026, 06:40:07 am
352314 Posts in 28957 Topics by 6926 Members
Latest Member: Chakalives
| | |-+  Turbos. Draw-through or Blow-through? Discuss
Author Topic: Turbos. Draw-through or Blow-through? Discuss  (Read 7851 times)
RUSS74GHIA
VWSP163
« on: December 22, 2009, 00:33:03 am »
I'm planning a draw through using a T05 and a Holley750. I've seen this set up a few times and it would appear to be a reasonably easy set up to build.
But what are the pros/cons of such a system?
OK, own up, who edited my sig?
Martin Greaves
10.88@128.58
« Reply #1 on: December 22, 2009, 00:37:23 am »
Oh dear Russ you gone and said it now.
Just you wait. Grin
james wotton
« Reply #2 on: December 22, 2009, 09:52:25 am »
personaly i think a blow is better than a pull ain't that right martin, Wink Grin
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
« Reply #3 on: December 22, 2009, 10:07:11 am »
Easy to build is the main pro, they do make decent power fairly easily. Disadvantage is that they aren't as flexible a system as a blow through.
I built a pull-through for my car several years ago but didn't get the ignition right so it didn't work too well. I took it off then and gave up - i might have another go one day!
I have no experience with a blow through system, just spoken to plenty of people who have!
The Reflex
« Reply #4 on: December 22, 2009, 11:34:09 am »
 Shocked Tut tut tut, keep it clean boys!  Wink
VWDRC164
Feel the fear and do it anyway
Jesse Wens
« Reply #5 on: December 22, 2009, 12:46:24 pm »
Since we run on propane we we're able to do a mix. The throttle valve is in blowthrough position but the venturi ( thing that meters gas) is mounted in the airfiltertube. We've got the response of a blowthrough with the simplicity of a drawthrough. The high octane number of gas is a pro too.
You'll probaby stick with petrol but i thought I'd share the info anyway.
JamieL
« Reply #6 on: December 22, 2009, 14:02:54 pm »
blow-thru, single throttle body + efi
by the time you've mucked around with fuel pumps, MSD/Mallory CDi and carbs and jets and sh!t, you may as well go for what will work in all situations rather than something that will always being a compromise somewhere...
Martin
Cash Converter....
« Reply #7 on: December 22, 2009, 14:07:58 pm »
x2
In the long run its cheaper. and you'll have a system you can put on any future motor.
Martin
www.taylormachine.co.uk
OFF/500
Tekken
www.proturbovw.com
« Reply #8 on: December 22, 2009, 16:45:00 pm »
Street or drag engine?
RUSS74GHIA
VWSP163
« Reply #9 on: December 23, 2009, 00:11:24 am »
Drag Grin
Turbo_Rich
« Reply #10 on: December 23, 2009, 23:21:27 pm »
I was originally planning on running a 750 draw through on my bug. I think they can be made to work reasonably well and certainly be an easier option if you just want a simple drag race setup. One question i would be asking is if you can get the turbo carbon sealed to prevent fuel leaking into the journal bearings. Personally I would go with a blow through setup- you aren't restricted where the turbo would sit- you wouldn't need the turbo seal, they can be mapped more precisely and have more control than the draw through setup you can also run an intercooler/chargecooler to make the air more dense for more power.
