November 04, 2026, 07:22:14 am
| | |-+  What does tranny maintenance consist of???
Author Topic: What does tranny maintenance consist of???  (Read 5756 times)
Brandon Sinclair
« on: December 24, 2009, 20:26:34 pm »
I have an IRS and as far as maintenance goes for me is once in a while I change the tranny fluid.  Is there any maintenance for the trannys (ie like the engines the heads need a valve job every so often), or do you just go until you have a problem.  Also, how many miles have you been able to get out of your tranny before going through it (normal daily driver tranny)?  I think I have 120k on mine and I am starting to wonder.
« Reply #1 on: December 24, 2009, 23:25:08 pm »
I'd look @ CV's and repack, replace boots.
« Reply #2 on: December 26, 2009, 21:01:49 pm »
Make sure your clutch freeplay is right (10-20mm).  If the clutch is dragging, it will tear up your synchros as they fight the clutch.
Rasser
« Reply #3 on: December 26, 2009, 22:47:34 pm »
Same thing when choosing which clutch disc to use. Donīt use the heavy types (black magic etc.), if you intend to help your synchros live long. Most people donīt give this much thought, but in theory light and small clutches should shift faster/easier and not wear the synchros as much.
Ras
1955 type1
1966 type2 13w deluxe
« Reply #4 on: December 27, 2009, 09:51:28 am »
Ras
intresting observation.
so what would be less harmfull in the end, a stronger pressureplate with a stock disc or a stock plate with a harsher disc (just putting out two extremes here as an example)
Rasser
« Reply #5 on: December 27, 2009, 14:15:44 pm »
Ras
Think about what happens when you put your clutch pedal to the floor....  Then the transaxle mainshaft only has the clutch disc "attached", and when you try to engage a new gear then the synchros have to speed up/slow down the gears/axles/clutch plate. Lighter/smaller parts will make the synchros job much easier and it will happen faster easier. IN THEORY.
Again, many people donīt give this much thought. But when you speedshift your gears with a heavy clutch, chances are you will warp/bend/wear your synchros much more than normal use will.
If the small bearing inside the crankshaft (for centering the transaxle mainshaft) is bad, then this will wear the parts too.
« Last Edit: December 27, 2009, 14:19:12 pm by Rasser » Logged
1955 type1
« Reply #6 on: December 27, 2009, 18:42:08 pm »
LOTS OF MAKE UP !
Speed-Randy
« Reply #7 on: December 28, 2009, 03:51:22 am »
I was wondering how long this was gonna take Roll Eyes
DKK Robert
« Reply #8 on: December 28, 2009, 04:00:01 am »
LOTS OF MAKE UP !
Don't Forget the beautiful dresses
« Last Edit: December 28, 2009, 04:03:23 am by Robert B » Logged
