June 10, 2026, 06:11:11 am
Latest Member: mvptkfjb
| | |-+  2017 build...horsepower estimates?
Author Topic: 2017 build...horsepower estimates?  (Read 30178 times)
bugnut68
« on: January 07, 2010, 00:42:44 am »
Okie dokie, here's my forthcoming combo:
78.4 stroke, 90.5 bore
8.5:1 compression
Engle 125 cam, 1.1 rockers
dual 45mm Dellortos
42x37 valves (steve times stage 2 heads)
1-5/8" exhaust
Any ideas on how much power, and what I can expect in the 1/8-mile with a 4.12 '70 IRS gearbox, car weight about 1700 lbs?  Stock gears, too.  Just curious of what my new engine potential may be... Grin
Hotrodvw
« Reply #1 on: January 07, 2010, 00:46:22 am »
Do you want a full throttle rating?   Cheesy
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
« Reply #2 on: January 07, 2010, 00:56:06 am »
sounds alot like the Cal Look motor Hot VW's did in mid 1990's that made in the region of 140hp (it was 90 x 78, 125 cam FF heads)
« Reply #3 on: January 07, 2010, 01:02:09 am »
Give it more compression!
bugnut68
« Reply #4 on: January 07, 2010, 02:57:36 am »
I asked Greg Tims about recommendations on compression, either 8.5 or 9:1, and he recommended I keep it around 8.5:1 for pump gas.
bugnut68
« Reply #5 on: January 07, 2010, 02:58:14 am »
I wish I still had that magazine... I think it was included in All About Performance VW Engines Part II, if I remember right, and I should still have that issue?
« Reply #6 on: January 07, 2010, 03:23:25 am »
140hp with the belt and mufflers. It made 162hp with IDAs, stinger and no belt.
neil68
« Reply #7 on: January 07, 2010, 06:25:44 am »
My 2017 cc, 42 x 37 044 Ultra Mag Plus CNC, Engle 120/1.25's, 7.9:1 CR,46 mm Kadrons (34 mm vents), 1 5/8" made 131 WHP on the Dynojet (probably 145 at flywheel?), 15.1 seconds in 1/4-mile at 3,300 ft elevation (maybe 14's at sea level?).
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #8 on: January 07, 2010, 07:02:38 am »
Sounds like fun engine to drive. And, yes... keep the compression where it is. Pump gas high performance engines are awesome. Excellent choice on the cam, too.
Brother Lovedub
« Reply #9 on: January 07, 2010, 09:31:05 am »
With those carbs and valves and that cam would 1:25 rockers not help the breathing?
bugnut68
« Reply #10 on: January 07, 2010, 18:39:39 pm »
I'm not completely firm on 1.1's, I was just told they would be easier on the valvetrain than 1.25's.  I'm around 4,800 feet elevation, any ideas on how this will impact the power output?  I'm looking forward greatly to putting this beast together... never had a stroker before. Grin
bugnut68
« Reply #11 on: January 07, 2010, 18:40:21 pm »
Neil, was that your '68 I saw in the Feb issue of Hot VWs (Great Canadian event coverage)?  If so, I love the car, looks great! 8-)
donkers
« Reply #12 on: January 07, 2010, 19:38:04 pm »
Almost exactly as I had in my ghia, in the full weight (heavy!) car with same gearbox ratio it ran consistent 14.8s  Smiley
edit-est' Hp was around 140
Only difference is I had fk8 and 1.4 rockers
bugnut68
« Reply #13 on: January 07, 2010, 20:33:46 pm »
Irregardless of numbers, it will be fun... can't wait! Grin
« Reply #14 on: January 07, 2010, 20:34:51 pm »
good attitude!
bugnut68
« Reply #15 on: January 07, 2010, 20:59:41 pm »
good attitude!
I'd like to make up a sticker for my rear window, in small letters, that reads, "No, it's not a damn Porsche engine!"  Lol Grin
Speed-Randy
« Reply #16 on: January 08, 2010, 02:47:02 am »
Compression makes power, raise yours to 9.5:1 and run super, it will be fine. Im running the exact same set up except i've got 92's and ida's, it runs fine on 91 octane. Doesn't ping unless ambient temp is 105 degrees or higher
« Last Edit: January 08, 2010, 02:49:10 am by vdubdweeb » Logged
mcmscott
« Reply #17 on: January 08, 2010, 03:16:09 am »
I say Twenty!!! Cry
Hotrodvw
« Reply #18 on: January 08, 2010, 07:27:08 am »
Ryan, you rode in my 2007cc, it didn't make the #'s you're seeing here.  If yours does, you'll have fun.   Wink
Hose & Fittings
'67 Sunroof
neil68
« Reply #19 on: January 08, 2010, 08:22:55 am »
Yes, that's me...I added some 94 mm Mahle slip-ins, Web 86C, 84 crank and IDA's, so now it's a 2332 cc Wink
Also, you mentioned being at 4,800 ft altitude.  I'm at 3,640 ft (and race at 3,300 ft) and I found 9.6:1 CR was just fine on pump gas with the above 2017 cc...I flycut the heads, which got me into the low 14's and was still a great street Beetle.  Good luck!
Neil
GreenTom
« Reply #20 on: January 08, 2010, 09:13:54 am »
I can scan for You that article if You need it. Is it the same number with Mr. Jim Kaforsky's 12 sec 2276?
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
« Reply #21 on: January 08, 2010, 09:49:50 am »
My guess for your HP: two times the half
 Grin
bugnut68
« Reply #22 on: January 08, 2010, 17:43:46 pm »
That's good info to know... I remember even the Bergs said in their instruction book that you can get away with more compression at higher elevation.  I figured that would be another important factor to throw in.
bugnut68
« Reply #23 on: January 08, 2010, 17:44:53 pm »
I was very impressed with how responsive that engine was in its form at the time... can't wait to see how the hairdryer adds to it!
Hotrodvw
« Reply #24 on: January 08, 2010, 21:25:44 pm »
I think it's gonna be fun.    Grin
Hose & Fittings
'67 Sunroof
fredy66
« Reply #25 on: April 13, 2010, 14:28:49 pm »
hello
looking at the 2017 looks to be a good street engine.
can i get a Way Whit the 4140 forced 78 crank??
and the rodes can i just the stock or is the I-beam rods ??
what barrels and pistons do i need ??
 ts a street engine for some Fun and long distens driving (finland to SSC)
thanks for the help
arabia slugs
Hotrodvw
« Reply #26 on: April 13, 2010, 15:21:37 pm »
hello
thanks for the help
I would go with a better rod than stock for sure....stock will take soem abuse, but there is better avail.  90.5 'B' stroker pistons and cylinders to match are what you need.
Hose & Fittings
'67 Sunroof
« Reply #27 on: April 13, 2010, 16:06:12 pm »
Ryan, go with 9:1 or even 9.5:1, mine is 9.8:1, no problems on pump gas 91 Oct. bunch of fun.  Wink
Black Sheep
less is more
« Reply #28 on: April 13, 2010, 18:06:22 pm »
Are you dead set on 90.5's ?
Coz I used to run a similar set up 2007 with 1,25's  good for about 130 bhp .
But..... if you go with 94's , would give you 2172 "I think" and up your compretion to 10:1 with some 1'25's and throw in a pair of 48's you got to be up around 170 bhp  Cool
I run 10:1 on optimax pump gas with no problems at all with my 2165 set up  Wink
« Last Edit: April 13, 2010, 18:21:06 pm by Black Sheep » Logged
13.03 @ 98mph
bugnut68
« Reply #29 on: April 13, 2010, 18:24:25 pm »
I'm definitely sticking with 90.5's... I simply have to stick with what I have, otherwise I will never get this thing built.  lol.  Same goes for 45 DRLA's, IDAs are out of the question for me, plus I've heard Dellortos have much better street driveability.  I basically have the essential components for this built at this stage, so I'm committed to it. Grin
