October 12, 2026, 16:46:23 pm
| | |-+  abandonned 65 and 2176cc bild
Pages: 1 [2] 3 Print
Author Topic: abandonned 65 and 2176cc bild  (Read 52281 times)
fredy66
« Reply #30 on: May 27, 2010, 07:53:42 am »
there is some plans
thinking to do  Roll Eyes
when time and money aloves it
fix the window some ignition problems and have a look at the towinn towoute
drop the rear one  clik when i could be bothered ( lasy Slug )
arabia slugs
fredy66
« Reply #31 on: July 18, 2010, 15:16:09 pm »
back home after Holiday 2300km in my bug Finland Sweden Norway
some photos
arabia slugs
fredy66
« Reply #32 on: July 18, 2010, 15:18:21 pm »
lots More here
http://s89.photobucket.com/albums/k207/fredy_66/2300km%20in%20a%20bug%20Finland%20Sweden%20Norway/
arabia slugs
peach_
« Reply #33 on: July 20, 2010, 22:23:54 pm »
 Cool
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
fredy66
« Reply #34 on: October 05, 2010, 22:17:56 pm »
time for a update Roll Eyes
some photos after i lowered  the rear. i,m thinking a bit to much we see
the engine is on the last time to do a new one  Undecided
lets see what the money can allowed this winter
stolen photos  Grin
arabia slugs
Zündfunke
« Reply #35 on: October 05, 2010, 22:35:37 pm »
Why did you lower the rear?!  Huh
Stance was just good before! Undecided
BURN OUT Syndrom
fredy66
« Reply #36 on: October 05, 2010, 22:36:22 pm »
have some new carbs.
not 48 IDAS but 30s2h made in poland  Grin
for free.
i,m thinking dual port 1300 and w110  9.1 comp
just for fun
all i need now is a 1300  Roll Eyes
anybody
and i have so 94 B pistons  for my next proget
« Last Edit: October 05, 2010, 22:43:02 pm by fredy66 » Logged
arabia slugs
fredy66
« Reply #37 on: October 05, 2010, 22:38:55 pm »
i wanted it flush weed the tires but ended up to low  Angry
arabia slugs
fredy66
« Reply #38 on: November 21, 2010, 22:08:18 pm »
so time for a upp date the 30 engine is sold
and so is the weird carbs  Grin
and i got a dual pot 1300 striped and ready to go for machining.
was toying weed the idea of doing a 30 hp phan skrued from a doghouse.
so i did some test cuts on old  phan skrued.
and some parts have arrived  Shocked
arabia slugs
fredy66
« Reply #39 on: November 21, 2010, 22:45:42 pm »
and the fan skrued
this is not done and its only a test
arabia slugs
fredy66
« Reply #40 on: January 24, 2011, 13:45:26 pm »
Time for a update
new ride hide
borrowed some Tbars
my sump raved
made a holder for my gages (that i don't have  Roll Eyes  ) probably oil temp
and a new stencil  Grin  covering a hole
arabia slugs
fredy66
« Reply #41 on: February 14, 2011, 22:54:23 pm »
did some sand blasting of the engine tins.
as my case is of for machining at the moment
and crank rods clutch and flywheel is at balancing
and tested the header paint that needs to be beaked at 160 c for 30 + minits
arabia slugs
wolfswest
« Reply #42 on: February 15, 2011, 10:43:58 am »
looks like you are planning to build a nice big engine for you ride.  I never read this topic, but I like what you did with the car.   Wink
Dem
fredy66
« Reply #43 on: March 16, 2011, 15:46:27 pm »
my parts is back from balancing thanks Jusi  Grin
crank
rods
block
lifters german modified  Grin
and the kep 1
Tanks Jusi
arabia slugs
« Reply #44 on: March 16, 2011, 20:49:14 pm »
Nice stuff!
fredy66
« Reply #45 on: March 16, 2011, 21:51:03 pm »
the main oil galleries is not drilled and tapped  Shocked
need to have a look at it.
 have do you clean the case after macing ??
arabia slugs
fredy66
« Reply #46 on: March 17, 2011, 00:51:25 am »
found this on the net .
do you relay drill and tap all the galleries  Huh
arabia slugs
fredy66
« Reply #47 on: March 24, 2011, 23:38:17 pm »
so i goth some free heads  Grin
Empi 40x35 there is a crack in them i need to have them looked at.
what do you think  Huh
the crack
arabia slugs
fredy66
« Reply #48 on: April 04, 2011, 01:43:37 am »
started some work on the case
what do think ?
did i miss something
« Last Edit: April 04, 2011, 05:35:42 am by fredy66 » Logged
arabia slugs
fredy66
« Reply #49 on: June 16, 2011, 12:48:02 pm »
time update
my bug have new ride hide  Grin
and i,m test assembling  the 2176 cc
hoping to have it ready this summer
need to swap for 12 v and open the gearbox for 200 flywheel.
got my 44 Weber and the heads is of for welding.
and my VDO
arabia slugs
fredy66
« Reply #50 on: September 11, 2011, 00:43:23 am »
a testing the fit of the engine
arabia slugs
« Reply #51 on: September 11, 2011, 01:33:19 am »
Late reply, but I did it on my case a couple of months ago. Since I prep the case too (I did the same thing that you did on it -except the rod clearance since I'll use a 74 crank-) I also drilled all the oil galleys plugs and taped them for a good cleaning and new plugs.
What cam are you using?
fredy66
« Reply #52 on: September 11, 2011, 01:47:18 am »
fk8 1.4 rokers
arabia slugs
« Reply #53 on: September 11, 2011, 01:50:09 am »
fk8 1.4 rokers
Thanks  Wink
fredy66
« Reply #54 on: September 11, 2011, 01:52:19 am »
its a copy of a engine from a magazine  Wink
arabia slugs
fredy66
« Reply #55 on: September 13, 2011, 00:42:08 am »
is it wort home porting found this but i,m not sore  if i,m doing more harm than good
http://knol.google.com/k/modifying-vw-type-1-cylinder-heads-for-performance#
arabia slugs
« Reply #56 on: September 13, 2011, 19:12:40 pm »
Thanks for the link, this is almost what I want to do with the 041 heads I have : cheap/free and home-made improvements (just to wait before I can afford perfect heads, bigger carbs and exhaust...)
« Last Edit: September 14, 2011, 14:01:48 pm by Nico86 » Logged
fredy66
« Reply #57 on: September 14, 2011, 11:32:38 am »
same problem here  Grin money  Angry
we See what hapends . send some photos when your done
arabia slugs
fredy66
« Reply #58 on: November 10, 2011, 22:49:35 pm »
had a friend of a friend water jet some gauge panels for men .
all i needed to do is bend it and make it look original.
attempt one Huh
any body in uk need one  Grin
that's not write.
attempt two
not done but getting there
arabia slugs
fredy66
« Reply #59 on: December 11, 2011, 09:38:51 am »
if any bod needs some gauge panels let me now
you need to bend it yourself
I have 20 coming soon
arabia slugs
