June 24, 2026, 14:07:03 pm
352201 Posts in 28917 Topics by 6920 Members
Latest Member: chris41
| | |-+  IRS rear suspension - need some help AGAIN ;)
Author Topic: IRS rear suspension - need some help AGAIN ;)  (Read 14696 times)
« on: January 12, 2010, 00:09:59 am »
Well guys as the title says I need some help with an IRS rear end I am working on at the moment, I need to identify it and find out some more about it,
You see this is a TOP SECRET Volksworld show project car that we have imported and getting ready for March  Wink
The Car has had an IRS rear end grafted into it and it looks a little odd to me  Undecided You see it has 2 (two) spring plates on each side  Shocked and the spring plate covers and spaced away from the torsion tubes,
Now before you all start telling me "They're adjustable" they are NOT as BOTH spring plate are bolted to the A arms with 4 (four) nuts/bolts as aposed to the normal 3 (three)  Undecided
I know this is a little hard with no pic's so I will get some tomorrow, But for now does anyone have any ideas on where this IRS rear end came from OR what these spring plates are all about  Undecided Smiley
Billyisgr8
« Reply #1 on: January 12, 2010, 02:58:38 am »
I think they are off a type 3.. it's a factory vw item.  They are on a freinds dune buggy sitting in my back yard right now.  Drag racers also use these to stop the flexing of one spring plate, I was thinking of putting some on my drag car too..
Kevin
« Reply #2 on: January 12, 2010, 04:11:27 am »
There's nothing unusual about that.  The IRS on that car is from a 68 autostick, or a 69-70 Beetle.  Or any IRS Type 3.
jamiep_jamiep
« Reply #3 on: January 12, 2010, 09:12:49 am »
If its being raced its fairly common to swap out the two piece spring plates for a single Lee. There's abunch of info on shop talk about them.
I have one of those early pans being built up for this seasons new race car, if you need any other info drop me a line.
karmann77
« Reply #4 on: January 13, 2010, 10:29:19 am »
I have a 71 semi auto KG that's got the same spring plates, had a right nightmare trying to get the correct spring plate covers for them because of the 4 spacers that you mentioned
« Reply #5 on: January 13, 2010, 10:41:43 am »
And now - single or dual springplates? I´m going to convert to IRS in spring 010 and I have a set of duals for the conversion. I believe that the covers are the same as for the single springplates, just longer bolts and spacers?
Jan
Stephan32
« Reply #6 on: January 13, 2010, 12:10:12 pm »
Bruce is correct, double plates where used on the Autostick due to the heavier gearbox!
Absolutely factory if you ask me!
I habve that set up on my IRS Pan which used to be Automatic!
Cheers Stephan
« Reply #7 on: January 14, 2010, 00:03:05 am »
Cool cheers guys  Smiley
It looked to good to be a aftermarket kit/homemade - so now I need to know how to lower it???
Are Both plates SPLINED??? any tips on refitting/lowering them???
Griebel
« Reply #8 on: January 14, 2010, 00:29:06 am »
The 2 plates don't come apart...one unit...lowering is business as usual  Wink
Cheers...
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
« Reply #9 on: January 14, 2010, 00:43:07 am »
Cheers...
Cheers bro Grin
« Reply #10 on: January 14, 2010, 07:52:29 am »
The covers are not the same.  The early covers for dual spring plates have spacers that are integral to the cover.  If you try to use separate spacers, it's a PITA to get them in place while you try to put the cover on.
If you're converting to IRS, always use the late TAs and single spring plates.  Much simpler, and significantly lighter too.
Stephan32
« Reply #11 on: January 14, 2010, 10:21:18 am »
Double plates are much stronger....
Lowering job is evil......
« Reply #12 on: January 14, 2010, 16:47:28 pm »
The stock single spring plates never break or bend.
« Reply #13 on: January 14, 2010, 19:05:30 pm »
Do you mean its harder to lower these double spring plate setups???
« Reply #14 on: January 15, 2010, 08:31:07 am »
That's right.  It's a bit of a fight to get the spring plate away from the TA when you're ready to pull the spring plate off.  There's less bolts with the later TAs too.
« Reply #15 on: January 15, 2010, 10:50:02 am »
It's only hard to lower it if you don't completely remove the IRS arm... I'm lowering a single plate IRS these days, and even that involves a lot of swearing if you don't remove/ disconnect the at least the drive shaft...
« Last Edit: January 15, 2010, 14:21:26 pm by JHU » Logged
« Reply #16 on: January 15, 2010, 12:00:30 pm »
 Shocked  Something lost in translation maybe Cheesy
Single plate is easy,never had to remove the d/shaft
cheers richie,uk
« Last Edit: January 15, 2010, 14:21:52 pm by JHU » Logged
« Reply #17 on: January 15, 2010, 13:17:55 pm »
cheers richie,uk
Yeah I know what you guys mean now - It can be tricky to lower a single plate type with the drivesharft still in place (it is on the "other chassis" I am doin)
I think it just depends on the car/chassis - I can imagine the doubles are alittle more tricky  Undecided
« Last Edit: January 15, 2010, 14:22:08 pm by JHU » Logged
« Reply #18 on: January 15, 2010, 14:22:13 pm »
 Grin
« Reply #19 on: January 15, 2010, 22:08:00 pm »
Grin
Hey,thats not right,it was much more fun before Cheesy
cheers richie,uk
« Reply #20 on: January 16, 2010, 06:34:07 am »
There's no need to remove the TA, and you don't need to remove the axle. Changing the ride height is easy with the later single spring plates.  Taking the axle off helps nothing, I don't understand why the Bentley says to do so.
« Reply #21 on: January 16, 2010, 11:14:32 am »
What I find is that pulling the springplate of the edge is harder when the TA covers about 2 cm of the top of the springplate. I bet it could be done with a prying bar, but I wanted to get it of in a controlled fashion so getting it back to the right height without to much testing.
BTW I'm talking about doing it on a super.
« Reply #22 on: April 13, 2010, 04:52:41 am »
Bottom line, can you convert double to single like on a 69'? And which is favorable for racing?
« Reply #23 on: April 13, 2010, 07:09:47 am »
To convert to 71 and later single spring plates, change the spring plates, torsion grommet covers, and the TAs.
The later single spring plate system is prefered because it is lighter.
Note, all IRS torsion bars are the same length, regardless of the CRAP you read on every seller's web site.
