September 01, 2026, 18:53:15 pm
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  "ROOM" "FOR RENT"
Pages: 1 ... 4 5 [6] 7 8 Print
Author Topic: "ROOM" "FOR RENT"  (Read 158437 times)
« Reply #150 on: January 30, 2010, 00:16:12 am »
Wink
« Last Edit: March 04, 2010, 04:40:01 am by TexasTom » Logged
« Reply #151 on: January 30, 2010, 00:27:35 am »
DG,
Exactly! It takes a long time to go in and clean that mess up before coating/painting! Then again, not many have metal & fab skills GabFab possesses ... wish I could.
If you taught a class, I'd enroll.
Love everytime you post some new pics of progress on BR's ride ... I should send you my '67 ... another project ...
OOJim,
My only question is how'd you come to 104? Makes sense, just would like to know how you got to that particular number  (trial & error?)... especially if you use that setting for different cams ... just very curious. Think I'll try it!
Also, the plenum manifold would be interesting to try on smaller carbs, like 40s. Possible they'd still meter low, but you'd also have both to pull on up high ... Huh Prolly depends on how much plenum you allow too ... and they'd need to be the same on each side ... starting to get complicated.
Too ... working on a small chamber street engine ... seem to remember you like that kind. Should get interesting when the chips start flyin off the flycutter!
DB,
Sorry to be late to comeaknockin on your door Wink
Diggin your stuff here ... you're an artist (have some of your art!) and a poet.
Valvetrain events are the things I'd really like to get to know much better ... I get the basics and understand the potential effects/affects ... just wanna know where it comes from. Where does the magic happen & why? I admire anyone that knows how to make the magic happen. I'd like to think I've come close a few times ... hmmm ... you've got me thinkin" I need to put together a 'trial' engine to try and get a better view of THE BIG PICTURE.
I guess I can't quite make out the trees in the forest ... YET!
Everytime you think you know, turn the page and there's another lesson to learn.
Thanks for the motivation ... ALL of You!
Now, I've got some work to learn Wink
Hi Tom, this has to be one of the most motivational posts round these parts in a while at least for me... it's a blast discussing this stuff.
I came upon 104 from a few reasons....  like I had posted somewhere up above, I was looking for point where on intake stroke (or exh, really, but...) where piston is at max velocity. Somewhere between (this was over 10 years ago now) the cut 94mm cylinder (cut in half longwise, like splitting a banana), a degree wheel, my Bosch handbook and screwing around with trig, it seemed that "104" was the magic number... it isn't, but ... the other reasons supported this, sort of, meaning a number of "engine guys" I talked to about cam timing, always suggested "104" (but they said "to make this cam run, advance it 4 deg"). One motor, believe it or not, I set up @ 102, but it was a 280@ .050 deal. Made good power too, peak @ 7100 with 40mm vents (2276).
somewhere I remember the number "72" coming into play, but now I don't remember where or why.  Roll Eyes
« Reply #152 on: January 30, 2010, 00:33:50 am »
It would be neat to have a set with a easy way of blocking the plenum, So on the dyno it could be back to backed. Also plenum volume would be important I bet.
Poor mans 58's
I wonder what the "other cylinder" is going to tell the pair of circuits though... meaning the one on compress or exh (Int valve still open?), with the usual manifolds, barrel # 3 has no clue what barrel # 4 is doing, unless one robs the other of fuel (dry float bowl).
I'm sure Doug has a better answer and explanation on "104"
DOUG BERG
« Reply #153 on: January 30, 2010, 01:00:08 am »
« Last Edit: February 02, 2010, 18:32:59 pm by DOUG BERG » Logged
DOUG BERG
« Reply #154 on: January 30, 2010, 01:14:16 am »
« Last Edit: February 02, 2010, 18:33:37 pm by DOUG BERG » Logged
« Reply #155 on: January 30, 2010, 01:21:38 am »
« Last Edit: March 04, 2010, 04:40:24 am by TexasTom » Logged
DOUG BERG
« Reply #156 on: January 30, 2010, 01:31:20 am »
« Last Edit: February 02, 2010, 18:34:02 pm by DOUG BERG » Logged
RFbuilt
« Reply #157 on: January 30, 2010, 12:44:18 pm »
hoping i can enter Doug's room and hope no one kicks me out by slapping the door on my back side on the way out  Cheesy
total newb to vw's  , more on the honda inline 4 stuff's and oddly enough some wisdom in the vw world works for inline 4s and maybe some on the inline 4s would work, maybe not.. but im sure  since their both IC engines..  i know id enjoy the knowledge..
back earlier (hope its not too late) Jim mentioned about  camming,  (hopefully not too overcammed)  a decent/small port or high velocity port'd engine,  in theory i think that should up the VE  if done right, provided the induction system is working in conjunction to the engine+ rpm + displacement and rod ratio , together once again with the exhaust system,
obviously there is more : over cammed, big daddy ports and big jugged motor, that tends to be lazy..
is there room to ramble about high velocity ports (provided we dont go to sonic choke) and hefty cams (duration)
Ralf
« Reply #158 on: January 30, 2010, 16:06:32 pm »
« Last Edit: March 04, 2010, 04:40:42 am by TexasTom » Logged
RFbuilt
« Reply #159 on: January 30, 2010, 16:11:19 pm »
very interesting!
hence i hinted on rod ratio on my post
(not like i said anything break through haha)
waitin on DB and JR  to enlighten us (oh specially me.. i need help)
« Reply #160 on: January 30, 2010, 19:51:32 pm »
« Last Edit: March 04, 2010, 04:41:02 am by TexasTom » Logged
DOUG BERG
« Reply #161 on: January 30, 2010, 22:32:17 pm »
« Last Edit: February 02, 2010, 18:34:34 pm by DOUG BERG » Logged
« Reply #162 on: January 30, 2010, 22:52:32 pm »
« Last Edit: March 04, 2010, 04:41:17 am by TexasTom » Logged
DOUG BERG
« Reply #163 on: January 30, 2010, 23:58:29 pm »
« Last Edit: February 02, 2010, 18:35:18 pm by DOUG BERG » Logged
DOUG BERG
« Reply #164 on: January 31, 2010, 00:03:29 am »
« Last Edit: February 02, 2010, 18:36:20 pm by DOUG BERG » Logged
DOUG BERG
« Reply #165 on: January 31, 2010, 00:06:14 am »
« Last Edit: February 02, 2010, 18:36:51 pm by DOUG BERG » Logged
DOUG BERG
« Reply #166 on: January 31, 2010, 00:08:47 am »
« Last Edit: February 02, 2010, 18:37:18 pm by DOUG BERG » Logged
DOUG BERG
« Reply #167 on: January 31, 2010, 02:30:59 am »
« Last Edit: February 02, 2010, 18:37:48 pm by DOUG BERG » Logged
DOUG BERG
« Reply #168 on: January 31, 2010, 02:38:25 am »
« Last Edit: February 02, 2010, 18:38:24 pm by DOUG BERG » Logged
DOUG BERG
« Reply #169 on: January 31, 2010, 02:40:17 am »
« Last Edit: February 02, 2010, 18:39:01 pm by DOUG BERG » Logged
DOUG BERG
« Reply #170 on: January 31, 2010, 02:44:19 am »
« Last Edit: February 02, 2010, 18:39:51 pm by DOUG BERG » Logged
DOUG BERG
« Reply #171 on: January 31, 2010, 02:51:36 am »
« Last Edit: February 02, 2010, 18:40:15 pm by DOUG BERG » Logged
RFbuilt
« Reply #172 on: January 31, 2010, 03:31:50 am »
wow thats one nice scenery,
down here in asia.. we dont have that haha
hmmm Doug,  the bear?  it looks like a cut lil dog/puppy on side view ?  Grin
DOUG BERG
« Reply #173 on: January 31, 2010, 06:45:51 am »
« Last Edit: February 02, 2010, 18:40:46 pm by DOUG BERG » Logged
DOUG BERG
« Reply #174 on: January 31, 2010, 08:02:58 am »
« Last Edit: February 02, 2010, 18:41:11 pm by DOUG BERG » Logged
DOUG BERG
« Reply #175 on: January 31, 2010, 08:28:26 am »
« Last Edit: February 02, 2010, 18:41:31 pm by DOUG BERG » Logged
DOUG BERG
« Reply #176 on: January 31, 2010, 09:55:17 am »
« Last Edit: February 02, 2010, 18:41:53 pm by DOUG BERG » Logged
« Reply #177 on: January 31, 2010, 14:29:01 pm »
Quote
PETER ,,,
              IT REALLY DOESN'T MATTER WHAT CAM WE USE   (FOR THIS EXAMPLE)    (OR ANY OTHER PART IN "THE SYSTEM")   SO; HERE IT GOES...
                 ANY CAM MOVED FROM A -0- (ZERO POSITION)   TO A FORWARD OR BACKWARD POSITION  "MOVES"    "THE POWER" AROUND !!!
                  SO IF "YOUR COMBO" CAN TURN 9000 RPM'S !!! (MAKE POWER THERE)  AND YOUR NOT USE'N "IT THERE" .... ON THE  STREETS  !!!
       "AND THEN" ADVANCE IT TO "A FORWARD POSITION"  (SAY +2/3DEG.)  YOU "TOOK POWER"    FROM 9000 R'S AND "MOVED IT DOWN" !!! (SAY TO 8000)
          AND GAIN'D "POWER" DOWN LOW !!!      (MORE TORQUE DOWN LOW)      EASIER TO MOVE THE WEIGHT OF THE CAR... "FROM A DEAD STOP"
                                       WAY MORE DRIVE-ABLE      (YOU ALSO QUIT WEAR'N IT OUT SO FAST !!! "IF YOU WERE TURN'N IT THERE")
        (YOU REALLY WONT "SEE THE LOSS" IF YOU NEVER WENT THAT HIGH !!!)
             ALSO IF YOU HAVE 42 VENTS .... (SAME 9000 RPM POWER CAPABILITIES)   "WE START'D AT"    (PRIOR TO OUR IMAGINARY CAM ADVANCE)
                          AND GO TO  SMALLER 40 VENTS...     ONCE AGAIN YOU TOOK POWER FROM UPSTAIRS AND MOVED IT DOWN !!!
                         OR....    MORE "BOTTOM END TORQUE"      WAY MORE DRIVE-ABLE !!!       "AND LAST'S A  HELL OF ALOT LONGER !!!
                               AND YOU "REALLY WONT NOTICE " THE LOSS CAUSE "YOU NEVER "RAN IT UP THAT HIGH IN THE 1ST. PLACE !!!
       "THE SAY'N IS" ....  "IT TAKES ENERGY TO MAKE ENERGY" !!!                 "THE OTHER SAY'N IS" .... "YOU HAVE TO GIVE A LITTLE,,, TO GET A LITTLE"
                                OR....  HOW 'BOUT.....   "YOU NEVER GET SOMETHING FOR NOTHING" !!!          ONE MORE WAY TO SAY IT IS ...
        "YOU HAVE TO MAKE A SACARIFICE TO MAKE A GAIN" !!!
        AND.....     "THATS THE IN'S & OUT'S" .....       "OF PLUS'S & MINUS'S !!!
     I SAID EARLIER :   SO  YOUR "WIFES & GIRLFRIENDS" COULD GET IT TOO !!!    "CLARITY OF THE ROOM"      VERY GLAD YOU ASK'D FOR A CLARIFCATION !!!
                                  IN "THE REPAIR BIZ".....   NO NEWS IS GOOD NEWS .....     SO IF I DONT SEE YA "IT MUSTA WORK'D" !!!
        LOVE DOUG...
Thanks Doug for the clarification!
To be honest, this is one of your first posts I could completely understand  Grin
I know for a streetcar it would be best to have more power down low, for drivability and all,
now, drivability or good manners dont really interest me ( maybe ignorance or lack of experience ),
I drive a diesel everyday, so for my weekend car I want a beast that turns some revs and keeps going harder.
I know I will have to sacrifice reliabitity, and drivability in traffic jams etc, but for me I think it will be worth the power on top, I thought because of the rpms, the HP gain (with retarded cam)would be higher compared to the torque gain (with advanced cam) off course it all depends on what people want..
I just love the screaming of my motor in that region. I am sorry, I am stubborn Smiley
DOUG BERG
« Reply #178 on: January 31, 2010, 17:56:37 pm »
« Last Edit: February 02, 2010, 18:42:23 pm by DOUG BERG » Logged
RFbuilt
« Reply #179 on: January 31, 2010, 18:02:49 pm »
wow keep it coming doug  or should i say keep it "going"
heard from an oldie about tightening lash to gain strength on "something" and loosening the others for anothe reason..
very interesting..
looks like that old guy who mentioned it wasnt sniffing GIN afterall LOL
he's not a vw guy though..
